Gear Shift Stuck
Old 07-25-2009
mkgonzales's Avatar
mkgonzales is an unknown quantity at this point
Post Gear Shift Stuck
I cannot press the button to allow my gear shift to release out of park. Recently, my brake light has been on & off when I drive, but I have had my brakes serviced. Could the brake sensor light be the problem?
Old 07-25-2009
^Warranty voider
Running Riot's Avatar
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
Re: Gear Shift Stuck
no codes?
Old 07-25-2009
CraigW's Avatar
Check to see if the brake lights in the rear are coming on when you step on the brake. See if the horn works (shared fuse)
f575gtc
Transmission
07-13-2015 09:16 PM
07-12-2015 11:54 AM
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
Steinar.D
Transmission
07-10-2015 01:38 AM
fvckbg
07-07-2015 07:08 PM
Quick Reply: Gear Shift Stuck
