Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-23-2009   #1 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
accord driver door light wont work
im trying to figure out why only the front driver door light wont work, but all three other doors do. the pin switch works fine and the dome light turns on/off when the door is opened/closed. any ideas? To remove this ad, register today for free or log in if already registered!
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Sponsored Links
Old 04-23-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: accord driver door light wont work
Could be broken wire in the door harness ?? Does the the light flicker or flash any if the door is swung back and forth ??
CraigW is online now   Reply With Quote
Old 04-23-2009   #3 (permalink)
gearbox
Super Moderator
if doesnt work at all no matter where the door position is. i even jiggled the rubber boot between the door and car and nothing. im guessing the wire completely broke cause all the other lights work and fuses are all fine.
__________________
www.lubecontrol.com
Member 1025782
Old 04-24-2009   #4 (permalink)
Da1lyDr1ver
Platinum Member
Da1lyDr1ver has a spectacular aura about Da1lyDr1ver has a spectacular aura about
Send a message via AIM to Da1lyDr1ver
i hear ya. my mom's '02 crv does the same thing for the drivers door. i cant imagine any wires behind the switch itself being loose, and the switch pushes in smoothly. i'm stumped too.
__________________
FOR SALE:
***OEM Honda Engine Block Warmer BNIB
***'01-'05 B&G S3 Full Coilovers
***RSX Front/Back Leather Seats (Tan)
***Autoguage Monster Tach
http://www.civicforums.com/forums/19...eats-tach.html
PM ME!!!
Da1lyDr1ver is offline   Reply With Quote
Old 04-24-2009   #5 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Those wires are just thin enough to get by. Not sure how hard it would be to run a new pair through the rubber boot. A bit of thinner speaker cable would be a good bet.
Old 04-24-2009   #6 (permalink)
Mr. Beefy
New Member
Mr. Beefy's Avatar
Mr. Beefy is an unknown quantity at this point
I'm sure you have a voltage test light.take the bulb out of the socket use the test light, check if you get power going to the light. if you don't have power then the wire might be pulled out of the light housing or you got a fried wire
__________________
May God have mercy on my enemies, Because I won't!
~Gen. Geroge S. Patton
Mr. Beefy is offline   Reply With Quote
Old 04-24-2009   #7 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned manahoonie should not be questioned
Send a message via AIM to manahoonie Send a message via MSN to manahoonie Send a message via Yahoo to manahoonie
sorry to ask it, but i don't see it mentioned as being done... (i know you may have checked it, but may not have listed it) although it sometimes slips the mind
bulb burnt out?
__________________
2002 Honda Civic LX Auto
7thGen.AT.C.
manahoonie is offline   Reply With Quote
Old 04-25-2009   #8 (permalink)
gearbox
Super Moderator
lol thanks but thats the first thing i tried. new bulb didnt work, the socket is connected to wires, but no power is at the terminals and they are not corroded. im inclined so far to believe a wire just broke since the driver door sees the most action obviously. the hard part is figuring out where this happened and how to fix lol. i guess i can take the panel off and pull some of the wires to see if one comes off.
__________________
www.lubecontrol.com
Member 1025782
Old 04-25-2009   #9 (permalink)
mrplow123456
Senior Member
mrplow123456's Avatar
mrplow123456 will become famous soon enough mrplow123456 will become famous soon enough
Wow your parents really beat the car. J/K anyway you said the dome light comes on but do they have a door ajar light in the gauge cluster? if so does that come on with the drivers door as well? Also is there a different alarm installed? One of the wires could have caused a problem in the circuit if so.
mrplow123456 is offline   Reply With Quote
Old 04-25-2009   #10 (permalink)
gearbox
Super Moderator
yeah the door ajar light on the dash comes on with driver door. it has aftermarket python alarm.
__________________
www.lubecontrol.com
Member 1025782
Old 04-26-2009   #11 (permalink)
mrplow123456
Senior Member
Well if the light still comes on, that was gonna be the fastest fix. With an aftermarket alarm there is a possibility that something isn't right with the wiring any more. How long has the light been like that? If you think it's been awhile I would start with the alarm since just about everything else has been taken care of.
If you haven't done it yet, take the door panel off and see if the window possibly pinched the wire running to the light or from where ever it comes.
Old 04-26-2009   #12 (permalink)
gearbox
Super Moderator
its been like this a long time, i never noticed when cause it happened when i was still out of town. i wouldnt know what to check with the alarm tho. ill open the door panel if its warm today lol.
__________________
www.lubecontrol.com
Member 1025782
Old 04-26-2009   #13 (permalink)
mrplow123456
Senior Member
Yeah I am not quite sure what to check with the alarm as I don't know how that specific one is wired to tell when the doors are open. If everything looks ok when you take the panel off, take a test light and probe the wire that is supposed to make the light come on and see if you have power. If you do, also check to see if the light still has ground. I don't think I have ever had so much trouble trying to fix something so small lol. Anyway good luck with it gear, I'm pretty much out of ideas after all that.
Tags
94 , accord , ajar , civic , cluster , dome , dont , door , drivers , honda , interior , light , pin , remove , switch , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
