Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-08-2009   #1 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
Might have made a huge D.I.Y. mistake
I was trying to remove the starting motor from my girlfriend's 1994 Si but the distributor looking thing was in the way....it has all the wires going to the spark plugs. I took the 3 bolts out of it, pulled it out and laid it aside. Then I noticed that a pile of oil (or something) had leaked out of the hole it goes into and the oil is now all over the engine, transmission and wires. I can clean that off but how do I refill it? Is it just simply pouring more oil into where it normally goes? Is this some special lubricant that has to be topped up a special way? I have no idea what I'm doing here. To remove this ad, register today for free or log in if already registered!
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Sponsored Links
Old 04-08-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Might have made a huge D.I.Y. mistake
you mean the distributor cap?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 04-08-2009   #3 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Damn.. My guess would be just oil... although I've never worked on a car with a distributor. Check the dipstick, is it lower then it was before you started working on it?
TRIZ is online now   Reply With Quote
Old 04-08-2009   #4 (permalink)
gearbox
Super Moderator
okay well im guessing that since you shouldnt have oil in the cap, you took out the whole distributor. im not good with this stuff either but i dont think oil shouldve come out at all. if you just took the cap off and oil came out, you need a new distributor.
__________________
www.lubecontrol.com
Member 1025782
Old 04-08-2009   #5 (permalink)
bakertime
Senior Member
bakertime's Avatar
bakertime is a jewel in the rough bakertime is a jewel in the rough bakertime is a jewel in the rough
The distributor is connected to the cam, so if you took the whole thing off, it doesn't seem too unusual for oil to come out. I've never taken mine off though, so I can't confirm from experience. However, I do know that if the distributor o-ring goes bad it will leak oil. So that leads me to believe that it is perfectly normal, assuming that you removed the entire thing like gearbox said. If you just took the cap off...then it is most definitely NOT normal.
You should just be able to re-install and then check your oil. If needed, just add it normally like you would after an oil change.
__________________
1997 Integra, Built N/A B18C1, 11.6:1 CR, tuned on a Hondata S200/ P28
2001 Civic EX, Ksports, Magnaflow Exh., SRI, SS - SOLD
bakertime is offline   Reply With Quote
Old 04-08-2009   #6 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Ya, I took the whole distributor out of the block, I figured it was connected to the cams. I'll try reinstalling and topping up with oil. Didn't want to turn the engine on until I was sure. Will it line up with the cams again on its own?
__________________
www.em2ab.com
D.I.Y. Debadge
Old 04-08-2009   #7 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
It's normal for some oil to leak out of the dizzy when you remove it. Replace the o-ring while you have it out and make sure you don't re-install it 180 degrees off. The 6th gen Civics is keyed in such a way that it can only bee installed correctly. Your 5th gen dizzy may not be keyed but you have a 50-50 chance of getting it right.
sql_civic is offline   Reply With Quote
Old 04-08-2009   #8 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
oops
__________________
www.em2ab.com
D.I.Y. Debadge
Old 04-08-2009   #9 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
im guessing you didnt mark the position of the distributor when you took it off either. if you feel a loss of power, get it retimed. it is normal for a few ounces of engine oil to spill out from the head when the distributor is removed. just check the level before you start the car up.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 04-08-2009   #10 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
and
Never try to save $100 by removing random parts from your engine. Or someone else's that may or may not deny you sex afterwards.
__________________
www.em2ab.com
D.I.Y. Debadge
Old 04-08-2009   #11 (permalink)
gearbox
Super Moderator
okay im joining the club. i tried to replace the dist rotor on a 92 accord, when i pulled off the old one i heard something metallic fall and jingle in the bay and i cant find it. does anyone know what that was? maybe a washer or something? also the old rotor felt loose i could turn it left and right quite a bit. i tried the new one hoping whatever fell out wasnt important and it felt nice and tight. i started the engine and it seems to be running fine? im still wondering what fell out tho.
idk about your situation tho, like mentioned on some cars, you can only put it back one way. but if this isnt the case, youre screwed and gonna have to get the timing set like skipbarber said.
__________________
www.lubecontrol.com
Member 1025782
Old 04-08-2009   #12 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
gearbox, is there something I can look at for you when replacing the distributor?
__________________
www.em2ab.com
D.I.Y. Debadge
Old 04-08-2009   #13 (permalink)
gearbox
Super Moderator
yeah if you dont mind, carefully pull off your rotor button and see if theres anything else on the gear shaft. the rotor is a small plastic piece that is on the side where the cap goes (inside, under the cap). it should just pull out and dont worry, it only goes back on one way. can you check and see if theres anything behind it after you pull it off, and also if you can turn the rotor LOOSELY when its installed. dont force turn it just use light pressure.
__________________
www.lubecontrol.com
Member 1025782
Old 04-08-2009   #14 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Will do buddy. I'm on Mountain time (same zone as you I think) so I'll have this done sometime before 10pm I guess.
__________________
www.em2ab.com
D.I.Y. Debadge
Old 04-08-2009   #15 (permalink)
gearbox
Super Moderator
okay thanks. i drove the car around to get more parts and all seems well so idk. i still wonder if a piece fell out.
__________________
www.lubecontrol.com
Member 1025782
Tags
2003 , 8th , ac , backup , civic , distributor , diy , drops , gen , honda , idle , installing , oring , release , sensor , trunk
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
