General Automotive DiscussionGeneral automotive discussion and chat. Honda, Toyota, Chevrolet, Ford. It doesn't matter, just talk about it here.
Welcome to civicforums.com!
Welcome to civicforums.com.
I am trying to find information about this error code and also a diagram of where this sensor is located. I am trying to figure out if its something I can change myself. I was reading my repair manual but it doesnt mention this sensor at all.
any help would be great
scott newell
Sponsored Links
Thanks for the info. could anything else be causing that error code? I am just wondering because last night I checked the batter connection, the spark plugs, cap and rotor. I think I need to change the rotor because it has oxidation on it but this morning my car started up great and the light didnt come on. If the sensor is bad wouldnt the light com on all the time?
Its on a 1999 Honda Civic VP model. running a 1.6L engine. According to Honda the TDC sensor is in the distributor itself and needs to be replace since they just dont sell the sensor.
so now I am trying to see if its the sensor or not. I think if the sensor is bad it would always be bad. And last night I unhooked the battery and cleaned the terminals, then I also check the cap out and the rotor. The rotor had some oxdiation on it so I cleaned that up a little with sand paper. this mornign when I started the car it ran fine and no engine light. My though was if the sensor is bad the engine light should have came back on shouldnt it? so I was going to see about changing the rotor and cap out to see if that helps.
Well that changes a whole lot. The D17 uses a cam trigger, which is where I said it was. The D16 uses something in the dizzy. If you can rig a fix and it works, then hey, but if not, I'd replace the dizzy. Without that sensor, the motor doesnt know where the cam is in relation to the crank, and it can't set fuel and timing with any sort of accuracy.
