Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-06-2002   #46 (permalink)
PerfectD3
Super Member
PerfectD3 is an unknown quantity at this point
Grey: Apexi makes one adjustable from 1k to 8k up to 25%. With piggybacks you can only increase the percent up to 25%, and that is pushing it realistically. With stock fuel system, pushing 25% over is putting the injectors dangerously close to a 100% Duty Cycle, which means shutdown. To remove this ad, register today for free or log in if already registered!
PerfectD3 is offline   Reply With Quote
Sponsored Links
Old 03-06-2002   #47 (permalink)
pinkytoe
Senior Member
pinkytoe is an unknown quantity at this point
Send a message via ICQ to pinkytoe Send a message via AIM to pinkytoe
THATS WHY I SAID GET NEW INJECTORS MAN-
pinkytoe is offline   Reply With Quote
Old 03-06-2002   #48 (permalink)
PerfectD3
Super Member
New injectors are not the only thing you will need. Will also need I higher flowing fuel pump and upgrade fuel pressure regulator, but that is the problem HKS is running into! The stock fuel system's pressure doesn't fluctuate like the 6th gen's. It does, but it is not enough to compensate for boost. HKS has a vast information database throughout its engineers, they definitely know more about this issue than anyone here, and with that said we can only wait until their kit is released. Then DIY turbo kits can be made by mimicking their kit, and the DIYers will get to decide what components they use (different name brands, ones that are more specialized for different products...) and the DIYers will save some serious $$$ because we won't have to pay the markup for such a kit and as your mother probably has told you, you won't have to pay more for the kit to have the HKS namebrand on it! Just be patient, because I seriously doubt any shop, having to handle various sales and installation jobs, will be able to devote as much time and energy as HKS will into making the kit, but they will have the time to mimic their idea.
Old 03-06-2002   #49 (permalink)
pinkytoe
Senior Member
PERFECT- ONE QUESTION ARE YOU READING MY POSTS?- I ALREADY SAID THAT ON THE 4TH PAGE THAT THE FUEL PUMP WE HAVE IS THE SAME AS THE 6TH GEN- EASY TO UPGRADE TO A 255LPH UNIT- THE INJECTORS ARE EASY TO GET AND THE FUEL MANAGEMNT IS UP TO YOU- OK?????? UNDERSTAND?
Old 03-06-2002   #50 (permalink)
WhosYoDadday85
www.ImportFactor.Com
WhosYoDadday85 should not be trusted WhosYoDadday85 should not be trusted
Send a message via AIM to WhosYoDadday85
Woah this is actually a post that we're learning from for once lol! It's been a while hasn't it
Also, pinkytoe, could you please stop typing in caps, its hard to read, and very annoying!
WhosYoDadday85 is offline   Reply With Quote
Old 03-06-2002   #51 (permalink)
PerfectD3
Super Member
Really? How the hell can we have the same fuel pump? The injectors are easy to get? WTF???? Have you been reading my posts about the fuel management?????? You can only trick the stock ECU with a piggyback up to 25%, but realistically you are looking more at 20 or so. With upgraded injectors, which I would like to know where the hell you are going to find those, using the stock ECU with a piggyback, you are going to have one hell of a time getting the correct map for the car! If this is your DIY approach, you are not going to be satisfied! Do you know how many hours you will have to be on a dyno with only having the ability to adjust 8 different RPM settings, not to mention even then you will not have the appropriate map for your car. I don't want to turn a good post into a flame war, but where the hell are you getting your information? Unfortunately you can't just slap a turbo up on our setup and adjust the stock fuel curve and hope everything works out for the best! Just be patient, like I have said, until HKS or any other makers that have a team of skilled engineers to come out with a properly tuned kit, then just mimic it.
Old 03-06-2002   #52 (permalink)
pinkytoe
Senior Member
HERE IS THE INJECTORS
HERES FUEL MANAGEMENT UP TO 50% AJUSTMENT
HERES THE IN TANK FUEL PUMP
OK BUDDIE- THE INFO YOU HAVE PROVIDED HAS BEEN EXLENT BUT YOUR MAKING A BIGGER DEAL OUT OF THIS ISSUE THEN IT REALLY IS- WELL GET THIS DONE TOGTHER MAN- OK????
Old 03-06-2002   #53 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
I still have some questions based on your last responses.
1. If you upgrade only to higher flow fuel injectors will that supply more fuel to the engine?
2. Do we have the same fuel pump as the 6th gen civic?
Grey is offline   Reply With Quote
Old 03-06-2002   #54 (permalink)
pinkytoe
Senior Member
1- IN CONJUNCTION WITH A HIGH FLOW FUEL PUMP AND A FUEL MANAGEMENT SYSTEM YES THEY WILL
2- YES- THEY ALL BASICLY WORK THE SAME
ITS THE SAME FUEL PUMP THAT REV HARD IS USING ON THE RSX CAR
Old 03-06-2002   #55 (permalink)
Grey
DIY King
Grey's Avatar
Ah, I see. So how is a higher flow injector different from a stock one? What makes it flow more fuel? What I mean is if you upgrade to a higher flow injector and a higher flow fuel pump, then nothing will happen without a fuel management system?
Also, will the stock FPR (Fuel Pressure Regulator) be able to handle a higher flow fuel pump? Maybe it's easier just to get the RSX's fuel pump/FPR/filter unit?
Old 03-06-2002   #56 (permalink)
PerfectD3
Super Member
Ok, but does RC make injectors for our cars?
Old 03-06-2002   #57 (permalink)
Grey
DIY King
Grey's Avatar
How about I e-mail them and find out?
Edit: Done, I'll post the reply if and when I get one.
Old 03-06-2002   #58 (permalink)
pinkytoe
Senior Member
YES THEY DO I ALREADY TALK TO TO THEM- THEY MAKE ALL INJECTORS- MY GIRLS DAD IS CHEEKING TOMMOROW ON THE FUEL FLOW OF AN RSX SET UP BUT I DONT THINK IT WILL BE ENOUGH ANYWAYS- THERE UP GRADING THE FUEL PUMP ON THE RSX WHEN PUTTING A TURBO ON IT- IT WILL BE JUST AS EASY WITH OUR SET UP AS WELL- SCREW THE RSX SET UP
Old 03-06-2002   #59 (permalink)
WhosYoDadday85
Pinkietoe, for someone who is trying to sell us a product, you sure don't act in a professional manner. Maybe you should think about things before you post stuff.... OK BUDDIE- DONT GET YOUR PANTIES INTO A TWIST- YOUR GETTING ALL WORKED UP- THE INFO YOU HAVE PROVIDED HAS BEEN EXLENT BUT YOUR MAKING A BIGGER DEAL OUT OF THIS ISSUE THEN IT REALLY IS- WELL GET THIS DONE TOGTHER MAN- OK????
Calm down, and stop typing in caps![IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old 03-06-2002   #60 (permalink)
Grey
DIY King
Grey's Avatar
Okay, then screw the RSX unit. What about the stock FPR (Fuel Pressure Regulator)? Will it be able to handle a higher flow fuel pump? It's probably not adjustable, right? We'll probably one that is adjustable from stock psi all the way up to the maximum psi of the fuel pump. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
