Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-05-2002   #16 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
I'm interested in the exhaust manifold. Only the exhaust manifold though. I would need to know if it could mate up to a Garrett T25 or T28 turbo with the turbo exhaust and intake openings facing the sides of the car. I would also need to know how it looks like. Pictures are worth a thousand words. The specifications would help me out as well. The injector flow rate is something I'm curious about. Why a T3/T4 turbo? That's huge, isn't it? What's the maximum boost pressure that you'll be able to run with one of those? To remove this ad, register today for free or log in if already registered!
Grey is offline   Reply With Quote
Sponsored Links
Old 03-05-2002   #17 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
Send a message via ICQ to Hwoody77 Send a message via AIM to Hwoody77
T3/T4
[IMG]i/expressions/face-icon-small-puke.gif[/IMG]T25
Hwoody77 is offline   Reply With Quote
Old 03-05-2002   #18 (permalink)
pinkytoe
Senior Member
pinkytoe is an unknown quantity at this point
Send a message via ICQ to pinkytoe Send a message via AIM to pinkytoe
definately grey- all im waiting for is my tax return to get started- i wanted to use a larger turbo so as a- im not stressing a small turbo to its max and most importantly- i can run more boost easily when i get to build the lower end- also the availibility of having sramble boost- hehehe ZOOOOOOM!!!
pinkytoe is offline   Reply With Quote
Old 03-05-2002   #19 (permalink)
bo0sT
Member
bo0sT is an unknown quantity at this point
A company called South Florida Performance makes many custom turbos and theirs should be ready anytime between now and the end of the month. they are also using the T3/T4 turbo. If you go strictly street legal in these cars you'll be all show and no "go"
bo0sT is offline   Reply With Quote
Old 03-05-2002   #20 (permalink)
black2k1vtec
Member
black2k1vtec is an unknown quantity at this point
What are you going to do about the return-less fuel system??
How will you add fuel as the boost rises??
How many PSI will it be running??
black2k1vtec is offline   Reply With Quote
Old 03-05-2002   #21 (permalink)
Grey
DIY King
Grey's Avatar
?sramble boost? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
The T3/4 hybrid is rated up to 200-400 horsepower (depending on compressor wheel). I don't think we need that much! If you're still thinking of using a T3/4 hybrid then check out this page: Installing the hybrid T3/T4 turbo.
Here's an image of the T25: Garrett T25
A T25 is limited to around 250 horsepower, maybe a T25/28 hybrid would be better? The T28 can produce upwards of 350-375 horsepower, so again I think that's too much. I don't know all the details yet, but I think a T3/4 hybrid turbo is too big for our engines.
Old 03-05-2002   #22 (permalink)
Hefe
Second Place is the First Loser
Hefe's Avatar
Hefe is a jewel in the rough Hefe is a jewel in the rough Hefe is a jewel in the rough
I'm gonna get flamed for this but oh well......... i don't know anything about turbos or superchargers
I 've been seeing a lot about this "returnless fuel system"..... what does that mean????
Also.... Where does the turbo fit on our cars... or any car for that matter
(Let the flaming begin)
DOH
Hefe is offline   Reply With Quote
Old 03-05-2002   #23 (permalink)
Grey
DIY King
Grey's Avatar
The returnless fuel system thing is where our cars do not have a fuel line going back into the gas tank from a pressure regulator up front. The fuel pump pumps out more than the engine needs and the fuel pressure regulator up front keeps that in check and returns excess amounts of fuel back to the gas tank. When upgrading to a turbo you can simply replace the fuel pump with one that flows more fuel and get a new fuel pressure regulator and crank up the max limit. Our cars do not have a return line, so the fuel pressure regulator is in the tank along with the fuel pump. That's what it's about, but I don't know what the exact problem is?
Take a look at this thread: Who was getting the turbo?
Old 03-05-2002   #24 (permalink)
Turtle
Senior Member
Turtle is an unknown quantity at this point
Send a message via AIM to Turtle
Im with Grey, the t3/4 hybrid is too big for a stock engine. Your are goning to have to build your bottom end to hold all that. Wait a minute, no one build stronger bottom ends for our cars!!! I think the T25 or 28 would be the best bet to go. I personally would only put a T3/4 on a DOHC powerplant, not these little single cams flower pots. And like what has beeen mentioned twice, how are you gonna get around the returnless fuel sys?????
Turtle is offline   Reply With Quote
Old 03-05-2002   #25 (permalink)
jaje
Member
jaje is an unknown quantity at this point
<< The returnless fuel system thing is where our cars do not have a fuel line going back into the gas tank from a pressure regulator up front. The fuel pump pumps out more than the engine needs and the fuel pressure regulator up front keeps that in check and returns excess amounts of fuel back to the gas tank. When upgrading to a turbo you can simply replace the fuel pump with one that flows more fuel and get a new fuel pressure regulator and crank up the max limit. Our cars do not have a return line, so the fuel pressure regulator is in the tank along with the fuel pump. That's what it's about, but I don't know what the exact problem is? >>
isn't the fuel pump for 7g civics and 4g tegs in the fuel tank so we can't change them either?
jaje is offline   Reply With Quote
Old 03-05-2002   #26 (permalink)
anibal
Super Member
anibal's Avatar
anibal is an unknown quantity at this point
I also agree with Grey and Turtle, T3/T4 are too big, you'll have a lot of lag with it, a smaller one should work better, faster spool up and more power through the entire rpm range...better for some twisties, not just drag
anibal is offline   Reply With Quote
Old 03-05-2002   #27 (permalink)
Grey
DIY King
Grey's Avatar
<< isn't the fuel pump for 7g civics and 4g tegs in the fuel tank so we can't change them either? >>
Yeah, it is in the fuel tank, but I think we can change it. Lift up your rear seat and you'll see an access port. I think you can get to it from there.
Old 03-06-2002   #28 (permalink)
pinkytoe
Senior Member
ok guys- definately very valid points- ill talk to josh- (the guy helping design) he has quite a bit of knoledge in the world of turbos- his current car is a 982 rwhp 300zx running dual t05's- the thought of the t4/t3 hybrid was the first off his lips- like i said before- i need a few more weeks to get everything stragined out- lets keep brainstorming and well see what we come up with K????????- oh btw what would be really nice is charts of diffrent turbo's outputs- i rember one site that had all the info on diffrent turbous- showing output and effecency- thanx guys- oh btw anything you guys come up with will help speed the process!!!!!!! okedoke??? good- oh and one more thing- after we all get this going WHO THE HELL WANTS A DAMN KIT!!!!!!! TURBO BABY!!!!!
Old 03-06-2002   #29 (permalink)
CIVIC808
Super Member
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
Send a message via AIM to CIVIC808
<< after we all get this going WHO THE HELL WANTS A DAMN KIT!!!!!!! TURBO BABY!!!!! >>
me... but the price needs to go down a bit, like a 1000. i was qouted about $4000 here to get it custom made.
CIVIC808 is offline   Reply With Quote
Old 03-06-2002   #30 (permalink)
pinkytoe
Senior Member
well as for teh price we need to see how many people want one and we need to see how much this kit turns out to be- alsoas far as the fuel system is concerned- its seems like an easy fix- just a matter of getting a pump and getting some kind of electronic fuel management system- no biggie
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
