General Automotive DiscussionGeneral automotive discussion and chat. Honda, Toyota, Chevrolet, Ford. It doesn't matter, just talk about it here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Money doesn't grow on trees...For an '01 civic, in Los Angeles, CA
Is $375.00 a fair price, to have the timing belt, the water pump, all the drive belts, the crank seal, and the cam seal replaced, and the radiator flushed?
This is from a trusted mechanic that only works on Hondas and Acuras and only uses Honda parts.
__________________ Giggity, Giggity, Gig-gi-ty!
Sponsored Links
water pump=100 bucks timing belt ~ 20-30 bucks. belts= no more than 20. crank seal-unsure cam seal-unsure. radiator flush- DIY. antifreeze would be around 20 bucks for the fluid. plus labor rate. so maybe. i wouldn't run that at all though.
To have it done, it is about 3-400 dollars. Always do the water pump with the belt, and do the seals. I might also do the tensioner, as they wear out too.
