Questions
Rep Power: 0 Questions
Questions:
1. I when to a local flea market I think I may be getting a good deal a 5" in. Pyle PLTV5N
http://www.millionbuy.com/pylpltv5n.html info on it and a 6 disk changer. What do you think good deal?
2.In your opinon what is would be the best fog lights on a Black lx. (as in blue one)
3. How would you DIY smoke headlights?
4.How do you hook up LED washer to turn on when you turn on your heads?
Thanks
Thanks
www.ImportFactor.Com
Rep Power: 0 1) No clue
2) PIAA fogs are pretty damn good, just make sure that they match up with your head lights. Get some white ones though...no yellow or anything
3) DIY smoking huh...I'm pretty iffy about this one, but here's what I'm thinking. Pull apart your head lights, buy some spray on tint stuff, and spray the inside of the lens. That should do it. Just make sure you get some practice first...I'm pretty sure that they make some stuff where you can spray it on, and if you don't like it, you can just peal it off.
4) For this, on your harness for your radio, there's a wire on it that gives 12v DC when you turn on your head lights. Tap into that. I think it's orange...but don't hold me to that. The wire is actually for your your dimmer switch if I do recall, so you can use your dimmer switch in the dash to change it to fully lighten up, or you can adjust it by turning the dimmer ****.
Hope this helps, good luck!
robjcivic
03-12-2017 12:10 PM
JMKendrick
09-16-2015 06:17 PM
Bricoleur
09-09-2015 12:23 PM
junkyardguy
09-02-2015 06:07 PM
