Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-12-2004   #1 (permalink)
pinkytube
New Member
pinkytube is an unknown quantity at this point
Need Help with Caliper Sliding Pins
My 2002 has two different "caliper slide pins"; These are the actual bolts which the caliper bolts on to. They slide within the pad bracket. I removed these to replace all the grease, and to clean them up, and replace the little grease/dust boots which were a little torn, and now I forgot which one goes where. There is one perfectly round one, and one with 5 or six sides like a hex bolt or something. there has to be a reason they were made different, and I need to know if the round one goes towards the front of the car, or towards the rear of the car? Any ideas?
Thanks
pinkytube is offline   Reply With Quote
Sponsored Links
Old 09-12-2004   #2 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
there should only be one pin per caliper. The bottom part of the caliper just unbolts, then you can swing the caliper up to change the pads. then the caliper slides out of the bracket from the top if you are doing other work. Other then that, I am not sure what you are asking.
streetglower is offline   Reply With Quote
Old 09-13-2004   #3 (permalink)
pinkytube
New Member
There are two pins which slide within the caliper bracket. When you remove the caliper completely from the car, the two sliders can be removed from the bracket also. They have black dust boots on them, and grease inside. One is perfectly round, and the other is kind of a hex shaped pin.
Old 09-13-2004   #4 (permalink)
streetglower
7thGen Junkie
show me a pic man, because I only have one sliding pin per side. When you unbolt the caliper on the bottom nut from the bracket, you can flip it upwards, then you can pull the top part out of the bracket. that is the sliding pin. Maybe we are thinking of 2 different things. Pics would be great though.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
