Difference between 2001 and 2002 the little details
Escaped Convict
Rep Power: 343 Difference between 2001 and 2002 the little details
its 4 AM and I'm bored.
I was clicking through Owner Link (honda's owner site, got lots of nifty info you all should check out)
and I decided to compare the difference between my 2001 Civic Coupe EX Side SRS 5-Speed with a 2002 Civic Coupe EX Side SRS 5-Speed
here are some difference I notice: (might be different for other models, didn't bother checking those.)
Valve Train: SOHC 16-Valve: VTEC-E (2001)
Valve Train: SOHC 16-Valve: VTEC (2002 - hp and torque rating are all the same. compression ratio too. I duon if its really the same VTEC or not anymore. heh. whats up with that. mileage is the same too.)
105,000 Mile Tune-Up Interval (2001)
110,000 Mile Tune-Up Interval (2002)
Body/Suspension/Chassis
Stabilizer Bars (mm, front/rear): 25.4/12.0 (2001)
Stabilizer Bars (mm, front/rear): 25.4/13.0 (2002)
Exterior Dimensions
Curb Weight (lbs., MT/AT): 2553/2590 (2001)
Curb Weight (lbs., MT/AT): 2555/2595 (2002)
these are some little details that people haven't mention before.
yes, aren't I bored? note the rear stabilizer bar is a bit bigger... must help a lot with the crap suspension. heh.
Exterior Dimensions
Rep Power: 0 Also, the back end of the 2002 model is a little more boxy and less roundy [IMG]i/expressions/face-icon-small-smile.gif[/IMG]. And the bottom part of the bumper where the exhaust comes out, the part that is cut out isn't as big as it is on the 2001.[IMG]i/expressions/moon.gif[/IMG]
Rep Power: 0 About the rear end being different... I heard it mentioned a few times but I don't really notice a diff. Can somebody post some pics and point out the differences?
Rep Power: 0 anyone know if the new style of rear bumper will make the 02 rear swaybar incompatible with our linkages or what? i dont suspect it will, but, well i jus hope it doesnt, hehe
CarStuff
12-06-2020 12:52 PM
SneakerPimp
11-28-2001 10:45 PM
03, 2001, 2002, civic, coupe, curb, differance, difference, differences, honda, interval, models, stabilizer, tune, weight
