Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-02-2005   #226 (permalink)
thiscrackerntam
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enough thiscrackerntam will become famous soon enough
Send a message via AIM to thiscrackerntam Send a message via Yahoo to thiscrackerntam
Quote:
well the question is this.
is the civic's speed limited by a governor on the indicated speed on the speedo.... or is it limited by a certain rev point in 5th gear.
if you saw 140 on your speedo, then it's probably limited by revs in 5th gear.
and you'd be amazed how off your speedo is up at those speeds. in a stock civic, if your speedo says 130mph, chances are you are only going about 121-125mph.
tires flex exponentially and directly in variation with the speed you are going, particularly as they reach their maximum speed rating. this causes a huge difference in indicated speed vs actual.
so yes, seeing as you have larger tires than stock, chances are at those speeds, your speedo is actually reading a good 15+mph OVER what you are ACTUALLY going.
My tires overall diamter are actually slightly smaller than stock... I've set both side by side, and the tire calculator on this website says so also.
thiscrackerntam is offline   Reply With Quote
Sponsored Links
Old 01-02-2005   #227 (permalink)
S2000man01
O RLY
S2000man01's Avatar
S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold
Send a message via AIM to S2000man01
actually i was just going to edit my post, but you beat me to it.
that makes perfect sense now.
when you DECREASE the overall diameter from stock, your speedo will read a FASTER indicated speed than what you are actually going.
if you INCREASE the overall diameter, obviously your indicated speed is SLOWER than what your actual speed is.
so yes, considering the tire flex at those speeds, i'm willing to bet had you kept going, you'd have quickly found your speed limiter, which i'm guessing is done by engine speed, not indicated speed on your speedo.
so yes though your speedo said 140mph, i'm willing to bet you were only going 125 or less. if you want, give me your original tire size, and your new tire size, and i can calculate roughly what your indicated speed vs actual speed would be at those speeds.
__________________
S2000man01 is offline   Reply With Quote
Old 01-02-2005   #228 (permalink)
thiscrackerntam
On a side note for S2000man01... If you look at my video in my gallery. My speedo shows I hit right around 100mph at the time I passed the 1/4mile on the track....my time slip for that pass if I remember correctly clocked me at lik 96mph... thats about a 4-6 mph difference in speed. Therefore my thoughts are this...your 15+mph speedo inaccuracy idea does not seem to make sense to me.
Old 01-02-2005   #229 (permalink)
thiscrackerntam
I'm betting that my speedo is off by 3-6 mph and I dont see how that margin of error can change regardless of what speed I'm traveling at. If it can change at all due to tire flex, I dont think it is going to change by very much if any at all.
Old 01-02-2005   #230 (permalink)
S2000man01
O RLY
S2000man01's Avatar
two things to note here:
number one, you'd be amazed how much tire flex changes your speedo reading. think about this. let's say your tires are a normal diameter of 20 inches. let's say that at 100mph, your tires rotate 40 times per second.
now, increase your tires to 20.7 inches. (rough estimate of tire flex) now, at 100mph, essentially your tires would be spinning only about 38 times per second. that's a HUGE difference. that's roughly 40 less inches you are traveling every second compared to your normal rate of speed.
if you were to continue at that speed, after 1 hour, that equates to almost 5 FULL MILES. this means from tire flex alone, your indicated speed is 5mph faster than actual. as you get faster, the tire flex increases, and of course, the variance grows. assuming the tire didn't flex any more, just think. at 150mph, that would be 7.5mph difference.
trust me, tire flex makes a much bigger difference than you think.
number 2, keep in mind, trap speed is measured by how long it takes you to cover the last 60 feet of the 1/4 mile. it's fairly accurate, but not as accurate as say radar or laser would be. there is probably about a -/+ 2 mph variance with trap speed vs actual speed.
i'm not making this stuff up. trust me, tires can flex even up to or greater than a full inch at higher speeds. especially tires that aren't rated for high speeds. plus throw in the fact that you are running a slightly smaller diameter than stock. i'm willing to gaurantee if i did the calculations (which i can do later when i have time) that your indicated 140mph is closer to an actual of around 125mph.
__________________
Old 01-02-2005   #231 (permalink)
thiscrackerntam
If the stock tire stands 1 inch taller than my 17s when you set them side by side then that should make up for that .7 inches worth of flex? Hmmmm You're still talking a 15mph difference on the speedo man, thats a huge difference. A very hard difference to believe...I dunno man.
Old 01-02-2005   #232 (permalink)
S2000man01
O RLY
S2000man01's Avatar
i should state that the lateral flex caused by traveling at higher speeds causes your speedo to read faster than you are actually going. you are confusing overall tire diameter with the lateral flex caused by rotation.
__________________
Old 01-02-2005   #233 (permalink)
98oRange
Member
98oRange's Avatar
98oRange is an unknown quantity at this point
Send a message via Yahoo to 98oRange
on my old truck they put too small tires on the back...
it made my speedo read faster than I was going...
at 30mph it said 32
40 it sed 45 and so on.
so s2000 man is right on that...
but if you are chipped to remove the governer you dont have to worry about it. anything over 15mph over the speed limit is jailtime regardless in most states...
__________________
Wait a minute! What am I doing.? I am far too sober for this.
98oRange is offline   Reply With Quote
Old 01-02-2005   #234 (permalink)
thiscrackerntam
how is the lateral flex of the tires' rotation that you're talking about going to cause the speedo to give a faster reading than what is actual when the flex is causing the over all diameter to increase, thus causing rpms of the wheel decrease for the same distance?
Old 01-02-2005   #235 (permalink)
S2000man01
O RLY
S2000man01's Avatar
because the contact patch gets smaller from the lateral flex of the tires.
__________________
Old 01-02-2005   #236 (permalink)
thiscrackerntam
^^right so therefore the tire does not have to rotate as many times to travel the same distance.
Old 01-02-2005   #237 (permalink)
S2000man01
O RLY
S2000man01's Avatar
ok i did the calculations. these are all WITHOUT tire flex.
at 100mph the stock tires spin 72.7 times per second. that means in one second, the car covers 1,760 inches. with your smaller diameter tires, you only cover 1,704 inches per second. over a one hour period, that's a 201,600 inch difference. etc etc, that equates to a 4mph difference in your speedo at 100mph vs actual speed from stock.
now, as we already know, cars in general in stock form, always show an indicated speed that is higher than your actual speed. on average, at 100mph, the difference is about 4mph. so, take the original 4mph, now add your 4, and your car is showing a total difference of 8mph so far at 100mph.
so... speedo on stock civic reads 100mph. actual speed is 96mph. your civic would be at 92mph.
now throw in any equation for lateral flex, plus the fact that at 140mph this difference is even greater. in fact, it's almost another 5mph. so now you're at an indicated 140mph, and your speedo is showing a difference of 14mph, meaning your actual is around 126mph.
just like i said it was.
__________________
Old 01-02-2005   #238 (permalink)
S2000man01
O RLY
S2000man01's Avatar
Quote:
no, it has to rotate MORE to travel the same distance.
__________________
Old 01-02-2005   #239 (permalink)
thiscrackerntam
^^not if the diameter of the tire is increasing due to the flex
Old 01-02-2005   #240 (permalink)
S2000man01
O RLY
S2000man01's Avatar
oh i get what you are saying now. yeah yeah my bad.
i was trying to show you two different examples of two contradicting things.
also note, that tires with less sidewall (like yours) tend to flex hardly at all, vs tires with bigger sidewall.
so tire flex in your case might increase your diameter .3 inches at most.
__________________
Tags
90 , civic , honda , octane , speed , top
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
