Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-09-2004   #1 (permalink)
HondaChevy
Senior Member
HondaChevy's Avatar
HondaChevy is an unknown quantity at this point
bench racing
This should get interesting.
Okay, somewhere there were multiple posts about the differences in our cars.
Manufacturer details:
LX: Torque -- 110; Horsepower -- 115; weight -- 2500 lbs. (power-weight ratio 21.7:1)
EX: Torque -- 114; Horsepower -- 127; weight -- 2579 lbs. (power-weight ratio 20.3:1)
Someone made the statement that LX cars have more torque, they don't. Someone said that driver skill makes a difference, yes and no...so that does not quite cut it either. Someone said that the LX is faster by not a lot because of the weight diff...well closer to the truth…but still not there--not everyone weighs the same or carries the same amount of crap in their car.
I have heard some say VTEC does not make a difference based on the numbers above…performance is about overall power and torque bands not just the peak numbers…so that theory gets KO’d.
I will tell you what does work though...how many heads, blocks, pistons, rods and so forth are produced out of the same mold before a new one is used? How much difference is there between cast #1 and cast #100--enough to make a performance difference. Trust me if you took 2 EX's and ran them with the same driver they would not be consistent, if you took two LX's and ran them...you got it...neither would they be consistent. That is why we dream about ported heads; balanced and blue printed, knife edged rotating assemblies; upgraded intake manifolds; larger bore t-bodies; more aggressive cams; bigger fuel rails; more air, more spark, more performance.
Let me ask you guys something else, when you buy a header do you just install it or have it installed right out of the box? You do right? Because that is the best it will ever be? Wrong! Take a look at the slop that is left from the welding and coatings inside the primary tubes and collectors that causes turbulence which in turn affects performance. Also, another small example--when you go to the local auto store and get new plugs (which is like every 100,000 miles right because that does not make that much of difference...keep believing that) you throw them in right out of the box because they are optimum and perfect that way...Lord help those of you who think like this. Other stuff to think about, how much un-sprung weight and rotational mass have you actually shaved or added with some of your upgrades? I could go with this type of thing all year long...but I won’t.
What I am getting at is that based on manufacture SAE-HP ratings (don’t get me started on that), and what kind of aftermarket parts you have on your car are not the only deciding factors—and sure as hell not the best ones—when bench racing a car (which is about a 60:40 game anyway). When was your engine and components cast or forged when it was put together, how well did you break the car in, how well do you maintain it—not just the motor oil and filter, but fuel filter (in our case fuel screen), spark plugs, timing, valve slack etc etc…, do you pay attention to fine tuning details or over look them…racing is a sport that requires paying attention to the fine details when building a car…plain and simple, next your combination of parts makes a difference, then being a knowledgeable, skilled and consistent driver comes into play…but without the whole package you just have about average.
__________________
I don't care what you drive...as long as you can drive.
HondaChevy is offline   Reply With Quote
Sponsored Links
Old 02-09-2004   #2 (permalink)
jdmb16ahatch
Senior Member
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
Send a message via AIM to jdmb16ahatch
uhhh all i can say about this is they more than likely also have different gears in the trannies which would also be another factor that would be added into the mix....but either way i could care less cause its still my grocery getter that handles good and looks decent....deffinately not a fast or race car nor will it be....its just to offey (spelling?) ill stick with the EF for racin
jdmb16ahatch is offline   Reply With Quote
Old 02-09-2004   #3 (permalink)
HondaChevy
Senior Member
HondaChevy's Avatar
Quote:
Yet another great example...let me also clarify something, this is not an EX biased post or an LX biased post...it is a general post to remind or inform, that is all.
__________________
Old 02-09-2004   #4 (permalink)
sadboy916
HISPAnIC CAUSIn PAnIC
sadboy916's Avatar
Send a message via Yahoo to sadboy916
who cares
sadboy916 is offline   Reply With Quote
Old 02-09-2004   #5 (permalink)
HondaChevy
Senior Member
HondaChevy's Avatar
The biggest reason I started this post is because I saw alot of debate on the topic around the site, wanted to put in my two-cents...instead of thread jacking someones thread, I got my own...something called a little respect.
Old 02-09-2004   #6 (permalink)
acidbaby
The Beez Kneez
acidbaby's Avatar
acidbaby will become famous soon enough acidbaby will become famous soon enough
__________________
http://img57.imageshack.us/img57/7607/signew0zy0vn.jpg
............____________
........../_____________\-NO->
......../(O)===\x/===(O)\-Bling->
.......|\_______________/|-Rat->
.......|_\_____________/_|-Mk2->
acidbaby is offline   Reply With Quote
Old 02-09-2004   #7 (permalink)
TheHughMan
Member
TheHughMan can only hope to improve
Send a message via AIM to TheHughMan
a lot of people do sadboy. it was an informative post about how there is a lot more that goes into a cars performance than the horsepower figure of the manufacturers website. how can you fault someone for trying to educate people on something they may not realize
TheHughMan is offline   Reply With Quote
Old 02-09-2004   #8 (permalink)
cambo
I wish I was asian
cambo's Avatar
cambo has a spectacular aura about cambo has a spectacular aura about
Send a message via AIM to cambo
its true that the performance of a car can vary depeding on build #, weight of person, etc.
but the reason most people use those figures is that its the easiest and its "in the perfect world" type situations.
Everyone knows that there are LOADS upon LOADS of other variables, but you account for everything.
as for the whole header scenerio you made...some people dont have the knowledge or the tools to make the header perfect. Also, they probably spent a good portion of their wallet on it and therefore dont want to add a chance that they might **** it up and end up wasting all that money. For the average tuner, out of the box and on the car is just fine.
you also dont account for the amount of time someone has to work on their car. Sure, you can spend 3 hours redoing the welds on a product, then spending another hour installing it. But that's 4 hour's worth of time that most people would rather spend doing something else, like spending time with their family or friends.
i'm in no way trying to make ur thread go sour, but you just have to account for what people think is worth their time and whats not.
__________________
The Many Faces of Badtz Maru!
http://filebox.vt.edu/users/nak/pict...ybadtzmaru.jpg
cambo is offline   Reply With Quote
Old 02-09-2004   #9 (permalink)
cambo
I wish I was asian
cambo's Avatar
Also, sure that adding a header with some imperfections in it may not give the best performance possible, but its most likely an improvement over stock (except for maybe DC Sports products ) and thats what most people care about. Its still an improvement right? Sure why not just leave it alone then, or at least until i have some more time to take everythign apart and make everything perfect.
__________________
Old 02-09-2004   #10 (permalink)
HondaChevy
Senior Member
HondaChevy's Avatar
Cambo, thank you for the reassurance that you are not trying to make my post go sour, but once again the main reason for the post was because I saw a lot of LX this LX that, EX this EX that, and just wanted to shed some light and or remind others that there is a lot more in a way a car performs than just stating “based on factory performance numbers” why an EX or LX is faster than the another.
In regards to how much time one spends on tuning a car and my references to fine tuning was an example of how people ignore what efforts go into a car. If I were to lose to another Civic with similar mods but a different packaged car (EX, LX) than I would know that they took more time into fine tuning their car than I did and that I did not lose simply because they had an EX or an LX.
I agree with you on the time and risk factor that goes into fine tuning some don’t wont to take the time others don’t know how, but by the same token I don’t have a lot of time on my hands, I am a husband and step-father of two girls, I work a 8-5 job plus outside contract work...I work hard for what I've got right along with everyone else on this site.
I just want people to understand that their are more deciding factors into why any model civic may or may not perfom as well as the same or different model civic--or any car for that matter, dont base it on just factory SAE-performance numbers.
__________________
Old 02-09-2004   #11 (permalink)
HondaChevy
Senior Member
HondaChevy's Avatar
Quote:
Did you take my post personal in anyway? If you did I appologize.
__________________
Old 02-09-2004   #12 (permalink)
cambo
I wish I was asian
cambo's Avatar
Quote:
once again, those people are just basing their opinions on ideal situations.
also, you need to understand that some people are rationalizing for their car trim purchase over the latter. No one wants to admit what they bought is inferior to another, except for maybe you DX owners out there .
__________________
Old 02-09-2004   #13 (permalink)
cambo
I wish I was asian
cambo's Avatar
no i didnt take it personal. Its just that you started a thread and i wasnt going to let it go one way. i wanted to make it more into a debate like thread where people can take a stand on. A LOT of people on this site jump on the bandwagon in any given thread. Didnt want that to happen in this thread because this could be a great thread given the opprunity (i know i killed that spelling) that people aren't afraid to voicing their opinions.
__________________
Old 02-09-2004   #14 (permalink)
Majarvis
2004 Acura EL - Premium
Majarvis's Avatar
Majarvis should not be trusted Majarvis should not be trusted Majarvis should not be trusted Majarvis should not be trusted
Re: bench racing
I have heard some say V-tec does not make a difference based on the numbers above…
Last time I checked it was called VTEC, not V-tec, or V-tech... Just thought I'd point this out to you seeing as you appear to be so passionate about this topic lease:
Majarvis is offline   Reply With Quote
Old 02-09-2004   #15 (permalink)
HondaChevy
Senior Member
HondaChevy's Avatar
I am glad that I did not offend, I appreciate the debate as opposed to argument.
But yet once again I must state that I agree that people may or may not have the time
to fine tune and yet it was a mere example as to why one LX or EX with a header, intake and
cat-back may lose to another LX or EX with the same parts. Please all, note that my thread is
not based solely on fine tuning but manufacture related issues as well.
__________________
Tags
power , ratio , weight
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
