General Automotive DiscussionGeneral automotive discussion and chat. Honda, Toyota, Chevrolet, Ford. It doesn't matter, just talk about it here.
Welcome to civicforums.com!
Welcome to civicforums.com.
I have run a dyno on my factory EX recently and discovered something probably weired. The max power occured at 6250rpm and rated 105.2HP and torque at around 4700rpm rated 100.8lb-ft. Is there something wrong there? It sound like the engine has no VTEC kicks in and that the power is even poorer than an HX....I have seen an 96-00 HX chart with power at 105.xHP and 99lb-ft torque factory....No modification to my car, and I did turn off every electrical thing. The A/F ratio of my car is always at around 12.4....What does it mean?
Sponsored Links
Also is that I installed a VAFC before and at 70mph the check engine light always come on and then I removed the controller and use only the fuel portion of it. The HP even went down to 102.8HP. WHat is the problem of the VTEC portion of the controller(cause check engine light on)?
The VAFC I used was the first version, not the VAFC-II. I have my friend worked on that but still can't get it fixed. When I was in 1st and 2nd, the car really pulls from 5500rpm on(I set the engagement point at 5500 initially), then 2nd, fine. Third, at 4000rpm, the light comes on with the code "VTEC rear band, code only, OK to drive"....Even 4th and 5th does the same at 70mph.
Therefore I returned the unit to my friend. Does VAFC-II work in this car with proper connection?
The dyno graph after I removed the VAFC shows a almost straight line from 3000 to 6800(where I set it to be the cut off), only +/- 1HP at several points. Normal?
The numbers look right. Anywhere from 100-110 whp is acceptable. VTEC engages around 3k rpms, but remember that it's VTEC-E (economy vtec) and doesn't help much for performance.
The original VAFC has problems with the check engine light and vtec. The VAFC-II has solved all this. Haven't you guys been reading all the threads posted about this?
well, was your engine broken in prior to the dyno runs? and you shouldn't be gettin constant Stoic 12.4 A/F reading, if you are doing WOT which you supposed to do on a dyno. a rich situation would be correct. it's also maybe your v-fac controller.
My EX doesn't say anything about VTEC-E. Still, it is ULEV rating, which is the same as the 2004 Acura TL. So I feel that it should be a regular VTEC, and VTEC-E actually has the VTEC-E embedded on the engine valve cover's electrical cover. And people told me that the car kicks in at around 5500 instead of 3k. It seems weired to me that the D16/D17 VTEC are classified as a VTEC-II, and VTEC-E for HX. Pretty confused.
