Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-11-2003   #31 (permalink)
IronFist
IronFist's Avatar
IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute
I don't think you have to put it in neutral first. Putting it in Park with your foot on the brake first will prevent the car from rolling. Then put the parking brake on, then release the foot brake. To remove this ad, register today for free or log in if already registered!
IronFist is offline   Reply With Quote
Sponsored Links
Old 11-11-2003   #32 (permalink)
Bellz
Diamond Member
Bellz's Avatar
Bellz has a spectacular aura about Bellz has a spectacular aura about
Send a message via ICQ to Bellz Send a message via AIM to Bellz
Post
You guys can be total car newbies sometimes. You should ALWAYS use the parking brake, ESPECIALLY on a hill.
Just for sh*ts and giggles, here's the info in the MANUAL p.188:
"Always use the parking brake when you park your car. The indicator on the instrument panel shows that the parking brake is not fully released; it does not indicate that the parking brake is firmly set. make sure the parking brake is set firmly or your car may roll if it is parked on an incline. If your car has an automatic transmission, set the parking brake before you put the transmission in Park. This keeps the car from moving and putting pressure on the parking mechanism in the transmission making it easier to move the shift lever out of Park when you want to drive away."
More info. For those of you that don't use it, I suggest you read the following:
http://auto.howstuffworks.com/automa...nsmission5.htm
__________________
'04 Element EX - Sunset Orange Pearl
The DX-Resource Website
Bellz is offline   Reply With Quote
Old 11-11-2003   #33 (permalink)
pheaton
A descendent of 2k1civic.com
pheaton's Avatar
pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light
Send a message via AIM to pheaton Send a message via MSN to pheaton Send a message via Yahoo to pheaton
^^^ yeah guys. . C'mon... seriously. There isn't much holding your car into gear when it comes to automatics. Beleive it or not, it's pretty much just a little pin. If the brake isn't on you're missing a last line of defense in the event that little pin (holding your car in park) is broken. If you are on a hill; the pin can break just with the force of car, not to mention what would happen if someone slightly rear ends you. Your call will skeet across the parking lot or down the hill it's sitting on, stripping your park gear clean out. Just a good idea to always use it. You shouldn't rely on the park gear alone. .
__________________
- Stay in front, that way you don't have to worry about passing anyone.
pheaton is offline   Reply With Quote
Old 11-12-2003   #34 (permalink)
Renamazazo
Platinum Member
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Send a message via AIM to Renamazazo
Here's something no one has said yet. IF you NEVER use your parking break, the cable becomes stiff, and brittle and will actually snap if you try to use it after not using it for years and years. and HONESTLY how freaking hard is it to pull up on that lever, it makes the cool clicking noise and everything.
Renamazazo is offline   Reply With Quote
Old 11-12-2003   #35 (permalink)
AzNmiKex215
2k1civic.com O. G.
AzNmiKex215's Avatar
AzNmiKex215 will become famous soon enough AzNmiKex215 will become famous soon enough
Send a message via AIM to AzNmiKex215
clicking noise 0wnz j0000
AzNmiKex215 is offline   Reply With Quote
Old 11-12-2003   #36 (permalink)
obtix
www.AbsouluteDriven.com
obtix's Avatar
obtix is an unknown quantity at this point
Send a message via AIM to obtix
Correct me if I am wrong here... But the parking brake locks the back wheels... while your put the car in park it is very simular to leaving it in gear on a manual. So yeah it will put some stress on the gears if you dont use the parking brake. I only had one auto car and I only used the brake if i was on a hill.
obtix is offline   Reply With Quote
Old 11-13-2003   #37 (permalink)
IRONMAN
Member
IRONMAN's Avatar
IRONMAN is an unknown quantity at this point
yup its just common sense.
IRONMAN is offline   Reply With Quote
Old 11-17-2003   #38 (permalink)
DrScottie
New Member
DrScottie is an unknown quantity at this point
Exclamation
Another point of note that no-one has mentioned either...
In addition to relieving the stress on the Park Gear Pin as mentioned above, Using your e-brake also adjusts the spring tension in the rear drum breaks. Thus it is an adjustment to the actual rear brake mechanism. It will increase the longevity of your drum breaks and provide better break application to the wheel.
so... ALWAYS USE YOUR E-BRAKE!
DrScottie is offline   Reply With Quote
Old 11-17-2003   #39 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
i taught my wife to always pull her ebrake on her auto. I had an auto and the pin started to go because I never used the ebrake. There is too much stress on the tranny from not putting the ebrake on.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 11-17-2003   #40 (permalink)
PICHY
ALGARETE
PICHY's Avatar
PICHY is a glorious beacon of light PICHY is a glorious beacon of light PICHY is a glorious beacon of light PICHY is a glorious beacon of light PICHY is a glorious beacon of light PICHY is a glorious beacon of light
Send a message via AIM to PICHY Send a message via MSN to PICHY
yo i use my brake all the time but i didnt kno u had to pull it b4 u put the car in park...wonder if i messed anithing up???SH!T das Fu#@ed up...
PICHY is offline   Reply With Quote
Old 11-17-2003   #41 (permalink)
PeteCivic2k1
Member
PeteCivic2k1 is an unknown quantity at this point
Send a message via AIM to PeteCivic2k1
If you all wanna have fun with the parking brake take two McDonalds trays, put them under the rear wheels, accelerate a little bit and pull the parking brake, then you will have some fun with it
PeteCivic2k1 is offline   Reply With Quote
Old 11-18-2003   #42 (permalink)
STEALTH_CIVIC
Member
STEALTH_CIVIC's Avatar
STEALTH_CIVIC is an unknown quantity at this point
every time i use it I forget that I have it on when I take off.. heh well it was early.. it happen once
STEALTH_CIVIC is offline   Reply With Quote
Old 11-18-2003   #43 (permalink)
CiViChiC20
Member
CiViChiC20's Avatar
CiViChiC20 is an unknown quantity at this point
Send a message via AIM to CiViChiC20
I use it all the time. It's a habit. My b/f got me doing it.
CiViChiC20 is offline   Reply With Quote
Old 05-03-2005   #44 (permalink)
Ricky
Member
Ricky's Avatar
Ricky is an unknown quantity at this point
Send a message via AIM to Ricky
i use mine i have a stick .. it will make you tranz last longer . i use it specially burning out and sliding the back tire when hitting turns lol
Ricky is offline   Reply With Quote
Old 05-03-2005   #45 (permalink)
claudeboi
im a psychopath...what are you looking at?
claudeboi's Avatar
claudeboi is an unknown quantity at this point
yea...dis is wat this thread ESTABLISHED, parking brakes relieves the gears!!! so use it...it wont hurt if you...
claudeboi is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
