2016 Civic makes knocking noise whenever hitting bumps
Rep Power: 0 2016 Civic makes knocking noise whenever hitting bumps
When I leased my Civic from Planet Honda, it had around 2 miles on the odometer. When I first drove it, it appeared to be fine. After about 200 miles or so, it started to make knocking noises on the front right side, and at the same time, the steering felt crooked and very loose, especially when making right turns. I took it back to the dealership and they determined that the right front shock absorber was defective, so they replaced it (or so they said). After driving away with a supposedly fixed car, the knocking noises persist, and the steering is still crooked and very loose. Is it possible they didn't do the repair work in the first place?
Rep Power: 0 2016 Civic sedan has loose steering
Is it just me, or does the 2016 Civic LX sedan have steering that is too light or loose? I feel like I have to slow down extra just to make a turn because I have to turn the steering wheel a lot to make the car turn. It feels much lighter than my old car, which was a 2014 Civic LX sedan.
Re: 2016 Civic makes knocking noise whenever hitting bumps
Take it back to the dealer.
Do NOT just tell them there is a noise and hand over the keys.
Take someone from the service department for a quick ride to demonstrate your issue. (Preferably the tech who will work on it) Do this so everyone is on the same page about what your issue is.
If you pick up the car and realize the problem is not fixed, turn around and take it back. Immediately.
Repeat until problem is fixed.
Re: 2016 Civic sedan has loose steering
You know how the car drove when it had 2 miles on it.
Wait until the problem above is fixed.
Test drive a couple other identical cars while you are waiting at the dealership.
Also.....I see a pattern here. It seems like your posting history is issues with potholes and loose steering complaints.
Rep Power: 0 Re: 2016 Civic sedan has loose steering
Post moved.
1996 and 2016 are not the same cars at all.
No comparison whatsoever.
In case anyone is searching posts for clunking from the front suspension, my 2016 Civic experienced a clunking over all bumps and it turned out to be a small rock trapped in the subframe tunnel where the front sway bar passes through. Dealer removed the sway bar and applied compressed air and rock came flying out. Reassembled and clunk was gone.
The following users liked this post:
BrotatoChip (11-03-2023)
