Air Conditioning Post your questions about air conditioning here!
AC Condensation Drain Line
Old 08-05-2016
fijiblue05's Avatar
fijiblue05 is an unknown quantity at this point
I have a 2016 Civic EX sedan.
This week I noticed water on the passenger side rear floorboard.
I used a towel to absorb it. I wasn't sure what could have caused it.
The next day it was heavily raining. (It's monsoon season and very humid.) There was a lot more water on both the front and rear floorboards. I used some more towels to absorb it and scheduled an appointment.
The next day (no rain) Honda went through a list of checks including a pressurized check of all the window/door seals and couldn't find anything. When I went home again, it was really wet again. I purchased a wet/dry vacuum and cleaned it up. I documented the amount of water in the vacuum.
The next day (no rain) there was more water again. So I vacuumed it again. I documented the amount of water in the vacuum. I was able to guess that it had something to do with the AC condensation. So I did a test drive, blasted the AC, then when I returned home there was more water. I vacuumed it again.
I scheduled an appointment the next morning with the new knowledge. They found a kink in the AC condensation line and they replaced the line.
I am posting this in case you have the same issue, you can have them check it also and hopefully save some time.
Old 08-05-2016
CraigW's Avatar
Re: AC Condensation Drain Line
Congrats on the new ride, and good to here you got problem resolved.
Old 08-05-2016
I bet there's still water underneath the carpet.
I'd try to make them strip the seats out and lift the carpet, put fans in there to dry out the padding under the carpet overnight. I've done this more times than I care to think about.
Or as soon as there's mildew smell, make them replace the entire carpet.
2003? Civic that had a big water leak, seats pulled and carpet lifted up all around (blocks of wood holding carpet up) with a big ol fan blowing under it:
Stupidface
Air Conditioning
22
08-11-2023 11:20 AM
mgcivicdriver
Engine start problems
16
12-10-2015 11:58 PM
badyellowvette
11-19-2015 10:04 AM
ezone
11-17-2015 06:56 PM
wawacito
12-07-2001 04:17 PM
Quick Reply: AC Condensation Drain Line
