will this fit and does it have a catalytic converter?
dean1w3
Rep Power: 0 will this fit and does it have a catalytic converter?
http://www.protuninglab.com/cbe-hc92...-hc88-hfc.html
Hey guys im wondering if this will not only fit my 00 civic sedan lx but im also wondering if its got a catalytic converter or would i need to purchase one. Any help is much appreciated thanks!!
Super Moderator
Re: will this fit and does it have a catalytic converter?
Maybe, technically
No. Your converter is currently attached to the manifold and this thing is designed to remove it completely. That's what a "test pipe" does.
Not only is that illegal in many (if not most) states, but at that price, I'd be leery of any of those parts' quality! You might want to suck it up and pay more for better "Hodna" parts elsewhere...
dean1w3
Rep Power: 0 Re: will this fit and does it have a catalytic converter?
Thanks
You got any suggestions?
My exhaust manifolds cracked and i want a full exhaust.
Super Moderator
Received 1,440 Likes
Rep Power: 338 Re: will this fit and does it have a catalytic converter?
me neither, but it's just that they don't last as long as OEM (I am still on my OEM, at 109k miles and still no signs of trouble). so, OEM you install and forget it (unless some other issues like misfires destroy the CAT and it won't meow anymore)
dean1w3
Ok so i need headers for an ex.(dc iv heard makes good **** so ill most likely end up going with them)
And a honda cat for an ex(if i want reliablility)
Will the ex header match up to my motor without major alterations?
And just so i got it straight if i get ex headers and an ex cat i also need an ex cat back system correct?
Super Moderator
Yep. The Honda e-store sells them expensive here, or you might find the OEM part cheaper elsewhere.
Yep, it bolts right on! Once again, check my sig!
That is correct!
PierrePierre
08-12-2015 02:42 PM
frisbeeguy2
07-30-2015 03:00 PM
fvckbg
07-07-2015 07:08 PM
