Design and machine your own parts...
Old 08-27-2004
master of the culinary martial arts
masarak's Avatar
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Has anyone used or heard of this online service?
http://www.emachineshop.com
Old 08-27-2004
Banned by Admin
Master's Avatar
K20 motor mounts here I come!!!
Old 08-27-2004
cdmx's Avatar
Yea right, I wouldn't trust that ****
Old 08-27-2004
masarak's Avatar
Well, I'm sure you have many valid reasons for your opinion, but here's the CNN article where I heard about this service:
http://www.cnn.com/2004/TECH/interne....ap/index.html
Although, I suppose you can always go to a local machine shop and see if they'll work with you.
Old 08-27-2004
Shifter's Avatar
Shifter is an unknown quantity at this point
Skeptical
There's one problem I see with this service that is not addressed (at least anywhere that I could find): Tolerances
How does the software know what the part's tolerances need to be? For example, if your part has a hole that needs to slide over a shaft, how can you tighten up the standard tolerance so that the part's hole isn't overly sloppy? There's only one MCAD software package that allows you to dimension (as per ANSI or ASME standards) a sold model completely, while including geometric tolerancing and that program is Pro-E's Wildfire.
Of course, maybe they're expecting you to detail a 2D drawing after creating a 3D solid model, but most people with no drafting knowledge will have a hard time doing this adequately when mating parts are required.
Needless to say, I'm a bit skeptical!
Old 08-28-2004
Fuzzy Boy
FuzzBeC00L's Avatar
Never heard that **** before
Old 08-28-2004
Jam out with your clam out.
abmerop18's Avatar
thats pretty cool
carid
09-28-2015 10:13 AM
Skunkone
09-24-2015 04:38 PM
Jrosa
09-14-2015 08:24 PM
Blackburied
09-12-2015 04:22 PM
Quick Reply: Design and machine your own parts...
