Quad retrofit
Re: Quad retrofit
Haha yeah! It sure is way better than the stock halogen output.
I only aligned the low beams as best as I could. I was also on a slight slope in a driveway so I had to adjust for that as well. I learned a lot from doing a quad retrofit, and if I ever do a next one, I will do it even better.
Originally, the FX-Rs called for a JB Steelstik/ JB Weld mounting method. However, it would not hold steady at all. Instead, I drilled holes in the reflector and housing and used nuts to hold the low beams in place at a good cutoff with them already in the housing torqued down.
Angel eyes
Hey guys. This is an update on my headlights from last month. I had wired the angel eyes but forgot to upload a picture. Well, here are the angel eyes that turn on with parking lights. I figured it would be a good option to wire them like that as there is no DRL relay in our civics unless you are in Canada.
Re: Quad retrofit
I admit it, I did not do the job right. My cutoff sucks, my driver headlight was not sealed proper with butyl rubber. And since I used ebay HID kits, my high beams wont turn on.
Im going to buy four headlights. Use two for temporary, and give the other two to a professional to redo a retrofit for me.
I will take my FX R projectors and re use them for my new retrofit. If I only do low beams, Ill sell the Mini H1s.
Question 1: Would you guys recommend just running one set of projectors (how it looks?
Question 2: Do angel eyes look ricey?
Question 3: Can our alternators handle running HIDs for both low beams, and high beams?
thanks! Im going to do it right this time!
Prelude Owner
Re: Quad retrofit
1.) I would for cost but 2 would look cool!
2.) Some people might think so but I dont.
3.) yes it should be able to handle it. The stock alternator can handle an amp and sub ok so it shouldn't have a problem with the HID's.
Super Moderator
Re: Quad retrofit
Depends on your definition of "ricey." I love mine, and I get compliments on them from time to time.
GolNat is right, as long as you aren't running 50-inch speakers and a 70-inch TV off the system. :P
Re: Quad retrofit
Bi-Xenon low beams with their solenoids linked up to halogen brights would be pretty badass. If I had an 04-05, I would have done that!
Just an update on the project.
The guy at Electronic Express is retrofitting the Mini H1s into some TYC brand headlight housings I bought from RockAuto.com. I will probably have them in a month. Currently I am riding around in stock headlights and stock halogen bulbs. I can live with it for now.
I ditched the angel eyes, as I wanted to keep it real simple.
I sold the FX-Rs projectors on Ebay.
While I do agree angel eyes can look nice, I think for the 03-05 models that keeping them simple is the way to go. I'm shooting for the OEM look as if our Civics came with low beam projectors from the factory. The only thing non-OEM would be the housing and trim being painted black.
Btw, I ordered my new HIDs from DDMTuning. I think they were 5000k 35watt with slim ballasts.
Ill post some pics of the retrofit in a month hopefully. I've attached of a pic of what the car currently looks like.
Received 1,146 Likes
Rep Power: 485 Re: Quad retrofit
Not to knock your current route, but a Morimoto mini install in OEM headlights is super easy. Just requires a bit of sanding on the back of the bowl for stock 9006's. Coulda been an easy DIY, just my 2 cents.
skip to 2:35
skip to 2:35
Rep Power: 0 Re: Quad retrofit
Good job, I think they look awesome! The double angel eyes are a bit much, I agree. Looking forward to doing an H1 or D2S retro on mine!
Be sure to post the results after they're re done!
