99 Civic Hazards/Turn Signal Stopped Working
Rep Power: 0 99 Civic Hazards/Turn Signal Stopped Working
Hi, just bought my first Civic recently. One day I started my car and my signals and hazards were no longer working. I replaced the hazard fuse under the hood, the turn signal fuse under the drivers side dash, and the flasher relay located next to the fuse box. I was sure that the new relay would work, and since it didn't, I'm stumped on what I could try next. Everything else dash panel related works just fine. It's only the hazards and the turn signals. Any help would be greatly appreciated!!
-Dustin
-Dustin
Re: 99 Civic Hazards/Turn Signal Stopped Working
Were either of the fuses blown? If there's a short then the new fuse(s) probably blew immediately. If not... bad ground would be the next most likely thing.
Rep Power: 0 Re: 99 Civic Hazards/Turn Signal Stopped Working
Thanks for the response! Neither of the fuses were blown, they were just discolored. I replaced them just to be on the safe side cause I had extra fuses anyway. But all the metal was perfectly intact so I don't think they were the issue. I've heard that the hazard relay is also the turn signal relay as well. Is this correct? Also, how would I check for a bad ground?
With a multimeter would be your best bet. Personally I'd check the bulbs an inspect the wiring to them first. Then start troubleshooting grounds. I took some screen shots from my FSM for my '99 EJ6 for some info on the ground and troubleshooting.
Hope it can help.
Hope it can help.
Braun
04-23-2015 09:03 PM
alexkharden
04-23-2015 07:13 PM
ashleymmackey
04-18-2015 09:48 PM
