West Alaska, Arizona, Colorado, Hawaii, Idaho, Montana, Nevada, New Mexico, Oregon, Utah, Washington, Wyoming
2013 Honda Civic Coupe
Old 02-15-2014
rayjeffries's Avatar
rayjeffries is an unknown quantity at this point
I purchased a new 2013 Honda Civic in July.
From the beginning the key didn't slide in & out of the ignition easily. I told my Honda salesman & he said to try some silicone spray, which didn't help.
A couple of months later, my wife when finished walking tried putting the key in the ignition with great difficulty she finally got it in. When she g2013ot home in the garage, she could not get the key out.
When I got it home, I finally got it out by wiggling it. Then I called my Honda dealer & they said to bring it in. I said I would if I could get the key back in. I got it started after much wiggling.
They replaced the ignition & replaced the 3 keys.
The new ignition & keys still didn't work as good as some other 2013 Civics in the lot.
Last week my wife got back from walking & she couldn't get the key in the ignition. when I got back I finally got the key in & got it started. Since then I have not taken the key out the ignition until I took the back to Honda dealer.
The technician said this is definitely not acceptable.
So they are going to call Honda on Monday.
Doesn't this sound strange that this happening to a new key & ignition?
Ray Jeffries raycj1@gmail.com
Old 02-15-2014
Re: 2013 Honda Civic Coupe
It's under warranty, let the dealer take care of it.
I have not heard any complaints at all, not until they are just plain worn out.
IMO Hondas "sidewinder" locks might feel a little bit different from a regular key and lock (depends on what you are used to).
They can be damaged by someone using force or maybe jamming a key in at a wrong angle.
I've seen them damaged by a poorly cut key.
They are a little finicky but work well if you are gentle.... but once damaged they don't work well (same as almost anything that gets damaged).
If you now have had 2 different sets of locks and keys that fail to work.......the problem may not be the car or the locks.
How much weight is on your keyrings?
Keys damaged or bent? It sure doesn't take much to cause problems.
Did they replace the rest of the lock set too?
If you now have to carry and use more than one key, someone could have tried to stuff the wrong key in the ignition. That might have damaged the lock.
Old 03-08-2014
jermuk's Avatar
jermuk is an unknown quantity at this point
I Want to buy this one:
HONDA CIVIC 2013
VIN 2HGFG3B50DH514384
Old 03-08-2014
Flood car.
Insurance claim as a total loss.
That means any factory warranty should have been cancelled.
miatabro
07-17-2015 12:12 PM
Pr0n1s
04-30-2015 03:08 PM
Civicman92296
04-23-2015 09:22 PM
jessicakaybby
04-20-2015 12:11 PM
Killagi
04-12-2015 10:42 AM
Quick Reply: 2013 Honda Civic Coupe
