93 civic dash & tail lights
Old 10-29-2015
Holokid's Avatar
Holokid is an unknown quantity at this point
I'm working on a 93 civic, the tail lights don't work. Brake lights are fine, turn signals work. Also, dash gauge lights don't work although the engine warning lights all seem to work. Bulbs replaced, no change. I was thinking that they are related, especially since they are supposed to turn on at the same time with the switch. I replaced the switch too, but that didn't help. I thought I had a bad ground, but I haven't found it yet. Does this sound familiar to anyone?
Old 10-29-2015
Re: 93 civic dash & tail lights
Check fuses?
#19 in the dash box
Old 10-30-2015
Holokid's Avatar
Yeah I checked the fuses first thing. I couldn't find any info on which fuse was for what, so I checked them all. They all look good. There are quite a few spots that are empty, I guess not used. 19 is empty. I put a fuse in it, no change. Where would I find a chart showing what the fuses are for?
Old 10-30-2015
Maybe an owners manual?
I certainly hope good wiring diagrams would have the info.
Does your local library have Alldata or Mitchell available?
Old 01-21-2016
dustin19d's Avatar
dustin19d is an unknown quantity at this point
Replace the dash light dimmer switch or make sure it's wired correctly. If still jacked up, replace the turn signal/headlight stalk.
hmrflores
06-20-2015 10:41 PM
silentz
06-17-2015 10:21 PM
Black91civic
06-06-2015 08:15 AM
civicPRODIGY
11-12-2001 09:32 PM
civicPesek
11-07-2001 11:33 PM
Quick Reply: 93 civic dash & tail lights
