Changing cluster
Rep Power: 0 Changing cluster
I'm just wondering if there would be any problems
With me installing a ex cluster. Cuz I have a cx cluster
Now. Or would it be eazyier to install a seperate
Rmp meter. Any suggestions ?? Would be
Very helpful
Very helpful
Rep Power: 787 Re: Changing cluster
usually clusters from the same year should swap. cars without tach almost always have the rpm wire already in the harness.
Did all the indicator lamps and gauges work when you swapped out the cluster? Any issues? I'm wanting to swap out my DX's cluster with an automatic's cluster for the tachometer.
Rep Power: 125 Re: Changing cluster
Not same animal but I have changed out two SR5 6 cylinder tac dash into my 4x4 Tacoma's 4 cylinders and they always seem to work fine. Not sure where it gets that tac imput but somehow it knows it's a 4 cylinder (I think??HA idle rpm matches spec..
Rep Power: 125 Thread
Kenji_Shinomori
06-19-2015 05:13 PM
jimmyfloyd
05-20-2015 07:06 PM
Ma213802
05-18-2015 07:01 AM
One_PeeJay
05-17-2015 05:31 PM
