speedometer problem 95 civic
Old 07-10-2011
B18_civic's Avatar
B18_civic is an unknown quantity at this point
I have a 95 civic that i got today. Rpm gauge works, but not speedometer. Would this be cluster or speed sensor???
Old 11-28-2011
tanker1975's Avatar
tanker1975 is an unknown quantity at this point
Re: speedometer problem 95 civic
Anyone figure this out? I have a DX and the same thing happens, speedometer not working, all other gauges working.
Old 12-17-2011
93CiviCex's Avatar
93CiviCex is an unknown quantity at this point
I have the same problem and was told that it's more likely the speed sensor since the other guages are working. Haven't fixed it yet though...
Old 12-17-2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
I think, not certain. Its the wheel sensor. I was reading on the ABS sensors and it would make sense. I have an ABS light myself that kicks on because one of my sensors is pooped and after 10mph it turns on the ABS light.
Hope ya figure it out. Not a terrible thing, but annoying as hell
Old 12-17-2011
ABS has nothing to do with the speedometer on a car that old.
Speedo runs off of the VSS in the trans. So does the PCM.
If the VSS was faulty (dead) there would be a code in the PCM for it, and a corresponding check engine light. A quick drive with a scanner would show vehicle speed on the display.
The car needs a speedometer head.
Pull the gauge cluster from the dash, then take it apart. Remove the speedometer assembly from the cluster. Turn it over, look at the back of it.
Most of the problems I see with them comes from the circuit board attached to the speedo, they need the components resoldered. If you can solder, and if the circuit board isn't coated in a protective layer of solid plastic, it can be a free repair (IF it works).
If 1/2 of the board is encased in hard layer of plastic, I haven't been able to remove that stuff to resolder the board. No fix, only replace in that case. Unless some electronics Guru has figured out a way around the stuff.
Old 12-17-2011
MrDobin's Avatar
Ouch. Gonna hope this doesnt happen to me
Old 12-18-2011
aidan/eg5's Avatar
aidan/eg5 is an unknown quantity at this point
has it always been like this or has it just started happening silly one but have you checked the sensors are all connected up right speedo sensor should be on top of the gear box just where the drives go in. try disconnect and reconnect it if it doesn't fix it its prob something to do with your clocks
Old 03-01-2012
mikeo's Avatar
mikeo is an unknown quantity at this point
I HAVE A 1992 HONDA CIVIC. tHE PROBLEM IS THAT THE INSTRUMENT PANEL HAS TWO PROBLEMS. 1. THE SPEEDOMETER DOESN'T WORK OR WORKS INTERMITTEN. WE CHECKED ALL THE PLUGS IN THE BACK AND THEY SEEM TO BE OK. WE DON'T SEE ANY SENSORS IN PLAIN SIGHT. IT HAS A MAOR CIRCUIT BOARD ON THE BACK OF THE PANEL BUT EVERYTHING LOOKS CLEAN AND UNTOUCHED. PROBLEM 2 IS THE LIGHTS IN THAT INSTRUMENT ASSEMBLY DOES NOT WORK. WHAT COULD BE THE PROBLEM. WE PUT IN A NEW MOTOR THAT HAS ONLY 35K MILES SO WE EXPECT TO BE DRIVING THIS CAR A FEW MORE YEARS.
Old 10-17-2012
panic989's Avatar
panic989 is an unknown quantity at this point
OK guys. I had his same problem and drove around for a good 6 months without a speedo. the rest of the gauge cluster worked but the speedo did not. The problem was that the speedo sensor in the transmission had bad ends to the sensor itself. Its a 10 mil bolt on top of the tranny with just a clip holding the wires in. I had to have my whole clip replaced because that was the my problem and it sounds like a few people are having similar problems. IF you are good with wiring you may be able to do this yoursel but I wasnt too sure what the initial problem was so I took it to a shop in Vegas called Force Fed Racing. If you areclose to vegas I would suggest checking him out and seeing if he can diagnose the problem. I had this problem on a gsr swapped eg hatch.
Old 02-12-2013
ttl
Slow Jammin'
ttl's Avatar
ttl is an unknown quantity at this point
i have the same problem in my 92 ex. If I bang on the dash it starts working again, so must be in the cluster wiring or on of the boards.
Old 02-12-2013
The problem is usually on the circuit board attached to the speedo itself, not the board on the back of the gauge cluster. You would have to pull the speedo out of the gauge cluster to see this board.
If the board isn't sealed (encased in a hard plastic-like coating IIRC), you can probably go retouch all of the solder connections for all the components and fix the intermittent break.
HTH
Old 02-13-2014
joeycivic94's Avatar
joeycivic94 is an unknown quantity at this point
My speedo im my 94 dx jumps and I can't figure out why it seems like it only happens when I have been driving for a while
Old 08-27-2017
Joseph Slone's Avatar
Joseph Slone is an unknown quantity at this point
Old post, but mine was resolved by replacing the battery. I had been intending to do so anyway, so no big deal. I did run the diagnostic test and the instrument cluster and that led me to either a batter or a fuse.
Old 09-23-2019
beneditti's Avatar
beneditti is an unknown quantity at this point
VSS is only like $5 on Amazon and it literally takes a minute to swap out. Wouldn't hurt to try.
Like someone else said, you'd get a check engine light for it, however, when I had that problem sometimes it would quit working but I the check engine light never came on.
TheMerrrr
07-20-2016 09:00 PM
greeen01civic4d
18
07-05-2011 08:16 PM
ryrex02
12-22-2010 09:03 PM
ryrex02
12-13-2010 12:34 PM
H3M1
06-03-2007 05:21 PM
Quick Reply: speedometer problem 95 civic
