does anyone know how to install fog lights
Rep Power: 172 Re: does anyone know how to install fog lights
lol i bought the kit then chopped it up in my car.lol i wired the two light grounds together then extended it to a switch in my car then grounded the switch. then i wired the two power wires together and put on a fuse and then straight into the battery. worked fine for me.
Rep Power: 0 Re: does anyone know how to install fog lights
ah man that sounds pretty complicated....but w/e i guess ill give it a shot. lol
it really aint all that bad. if you are good with electronics and wiring. i mean i did all that in less than 30 mins
Canadian, Eh!
Rep Power: 252 Re: does anyone know how to install fog lights
Are you wiring it to your lights or a separate switch? It sounds like you just need a lesson in how electricity works.
Does your car have an OEM foglight switch? You could pull the power from the headlights so anytime the headlights are on your fogs would come on, however you dont want to draw too much out of your headlights.. Use a spdt relay:
87: connect to battery 12+v (use fuse in line)
85: ground (-)
86: wire tapped into +12v from headlights (or any other positive switched source that you want your fogs to come on with)
30: connect this to your +12v wire going TO the fog lights..
Very easy to do, make sure you test all your wires.
I would also use this method instead of running just an on/off switch, this is safer and would allow more power to your lights (brighter)
85: ground (-)
hmm....well im not much of an electrician but ill give it a shot...and yea, it came with a switch. kinda wondering how am gonna connect it from the engine bay to the dash though??
Canadian, Eh!
There are a number of ways but I still need to know if you're going to connect it to a switch or to be automatic with your headlights/parklights.
the kit supplied me with a switch...but for some reason i tried to connect the connection end to the switch and it didnt want to fit in.
so im kinda skeptical if i should even use that switch....
Canadian, Eh!
Jesus Christ, this is my last attempt at helping you. Forget about what fits, if you want to use a switch, you can. Now would you rather have them on a switch or automated with your current lights?
The positives with the switch is they're only on if you want them on. The negatives if you hook it up wrong is they could stay on after you turn your car off and you might not notice, draining your battery.
Canadian, Eh!
Not so much use it for power but you could use that power to click over a relay and get power from the relay, that would work. Or use an Add-A-Circuit to get power from the fuse panel. If I can get an answer I can write it up.
Received 1,146 Likes
Rep Power: 485 Re: does anyone know how to install fog lights
here's a basic wiring schematic.
the red 12vdc line is your choice. Choose one: hot at all times, hot when the car's on, hot when the parking lights are on, hot when the headlights are on. If you don't know what I mean by "hot" that means "live" as in, if connected to a ground, it will complete a 12VDC circuit.
Alright!! I got it......but now cutting the bumper is a differnt story. Aaahhh!! I'm gonna try to rent a power tool for this....>.<
i just used a metal saw. you know the ones that are kinda like a knife? it worked pretty damn well. i first drilled a hole then got to cutting. i'd drill holes in all four corners.
When I cut out the black part of my bumper to fit my intercooler, I used a dremel.. Not the cleanest work, but I didn't really care.
i used a dremmel to start too. but then it just melted the plastic.lol then i ended up using a metal saw. it was quick and easy. and it was a pretty clean cut. but imma have to buy another kit cause when i hit the deer it broke one of them... damn deer. and they were smoked extra dark.lol
lol...dam those deers!!
alright, imma attempt this on saturday,much thanks for the helps guys.
lol yea i thought about becoming a redneck deer hunter that dont care bout legal limits for a bout an hour while i was standing there.lol ugh. but there are alot out here but obviously not enough.lol and good luck on the install it really shouldnt be hard. but again the simpler it is the easier it is to f up.lol
aaahhh i successfully installed the lights onto my bumber, but when i was puttin the bumper back on,it didnt fit with the foglights installed >.< //i think i might have to cut a bit more from the bumper....
i think its a tight fit, like my horn sounds different now if you notice the horn harness is right by the left fog light so i think my fog light is hitting it and its not sounding the same...make sure your wires are all tucked in and the black plastic stuff under the car is also tucked in under the bumper
