1989 Civic Intermittent Starting Issues.
Old 04-17-2017
TI 3VOM's Avatar
TI 3VOM is an unknown quantity at this point
My son just bought a 1989 Honda Civic 4 dr sedan. It starts most of the time, but other times it will just turn over. If you pour some gas into the throttle body, it will fire right up till it uses up that gas, then die. Let it sit a bit and it will fire right up. Doesn't seem to matter, cold, hot, previously running or start of day. It's hit and miss. I changed the fuel pump, still the same. What else should I be checking? Intermittent fuel relay? ECU?
Old 04-20-2017
Super Moderator
Poopies's Avatar
Re: 1989 Civic Intermittent Starting Issues.
Spark plugs look ok? Battery is good? How about those fuel injectors? Are they ticking like they should?
