1995 15 ACG fuse Blows
Old 01-30-2017
Benjamin Phelps's Avatar
Benjamin Phelps is an unknown quantity at this point
Question 1995 15 ACG fuse Blows
Need advice on where to look next. Car runs fine starts and I can idle it at 4K RPM with no problems. I drive the car easy under 50 MPH and don't let the RPM's hit over 3K I am fine. The second I push the car to 3.2RPM under power the 15 AMP ACG fuse blows. I replace the fuse and drive the car as described above and its fine. I have replaced the Distributer, I have replaced the Fuel pump. Looking for ideas on where to search next.... this is not a random problem either, it is consistent specific, happens every time...
Old 01-30-2017
The legs in the public bathroom stall
mcnoople's Avatar
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: 1995 15 ACG fuse Blows
I would look for a spot in the engine wiring harness that is moving with the engine. Sounds like something is grounding out when the engine is torqued in the mounts. I would suspect a wire has rubbed through and is grounding against an engine bracket. I recall this being a common issue on the harness behind and under the intake manifold, but I do NOT remember which years had the problem.
Get a copy of the wiring harness for the car. There are online resources that can supply a diagram. With the diagram you should be able to trace every wire that is supplied power by that fuse. The problem HAS to be in a wire or component on that circuit. In the factory book the fuses each have their own diagram with components listed.
A haynes/chiltons wire diagram is NOT a good reliable source of information.
Old 01-30-2017
Thanks for the reply... I will be looking for wiring harness. I was able to double check all the wiring and clean a few things up, now it is working under all torque, thru all gears - Now its popping the fuse when we hit 60 MPH - consistently......
