91 D15 IAC Bypass?
Old 04-28-2015
mievil's Avatar
mievil is an unknown quantity at this point
91 D15 IAC Bypass?
Hi, all. First post here. I've been searching Google for seemingly forever with no good results. And admittedly this is my first Honda, so maybe I am not searching for the correct metrics.
I have a 1991 DX that has developed a small coolant leak on the HOSE, ELECTRONIC AIR CONTROL VALVE OUTLET, PN 19507-PM5-A00. It seems to be leaking on both ends of this short hose. I originally relocated the upper clamp as it seemed to be in a strange location. After this it seemed to stop leaking at the top but was still leaking at the bottom. After the daily commute is still leaking at both ends.
I was merely going to replace the hose and both mildly corroded clamps. However, I stumbled across some IAC bypass threads and it got me to wondering. Only hitch being every thread I found was involving the newer motors.
So, I have a request for help. I am looking for a coolant flow diagram for this motor, or just a simple instruction. I have been digging through my Chilton's manual and finding it extremely lacking in info. If I could get the coolant flow diagram of this guy it should be super easy.
OR, I am figuring I just need to connect the bypass hose from the small nipple on the water pipe on the passenger side to the small nipple on the intake manifold directly above the larger hose coming from the thermostat, thus creating the "bypass", then capping the extra nipples surrounding the throttle body that are no longer used. Does this seem correct to anyone?
I've seen threads with block off plates and all sorts of other awesome stuff, but nothing seems to be regarding this particular motor. Following the hose path it seems that I can not use everything from the top side of the intake manifold all the way to the bottom of the throttle body. But I just want some verification of this.
Thanks for the help on my long winded assistance request.
Old 04-28-2015
Re: 91 D15 IAC Bypass?
I'd say just replace the leaking hoses and clamps.
Old 04-28-2015
mievil's Avatar
I did just replace the suspect hose, but would still be interested in the correct bypass. Thanks.
h4ldol
04-24-2017 08:16 PM
Rlss
24
02-26-2016 09:42 PM
RSKtakR
25
09-14-2015 07:43 PM
thaler4cuse
09-07-2015 08:25 PM
geforce789
08-19-2015 06:17 AM
Quick Reply: 91 D15 IAC Bypass?
