I can't figure out clicking noise
Old 07-30-2014
laddsqu's Avatar
laddsqu is an unknown quantity at this point
I have a 95 lx sedan 5 speed with a d15b2 block d16z6 head
D15b7 intake manifold I just got it a week ago
It's making a wierd clicking noise I can't pinpoint
I'm attaching a video of the noise
https://www.google.com/url?sa=t&sour...bENxdAdOyWfylQ
Old 07-30-2014
Re: I can't figure out clicking noise
Got oil?
What's it sound like if you hold the RPM at 2000?
Old 07-30-2014
laddsqu's Avatar
Yea I have plenty of oil at 2000 rpm it stutters if I hold it
doesn't idle till its warm though if that helps
Old 07-30-2014
Video?
With decent audio?
Video of you slowly raising and lowering the RPM to make the noise happen loudest?
Old 07-30-2014
laddsqu's Avatar
I'm working right now I can post one in the morning when I get home
Old 07-31-2014
laddsqu's Avatar
i apoligize for the audio all i have is my phone the in car video shows me slowly rolling the throttle on and as far as i can tell the sound only happens when i let off the gas
Old 07-31-2014
In the first video it seems like I hear a loud couple of 'clack clack' noises as the engine comes down to idle speed, then around :57 or so it sounds like the clacking became more consistent as the engine idles.
VTEC pins (between rocker arms) not releasing fully, or sticking?
Valve adjustment?
Old 08-07-2014
laddsqu's Avatar
I just found a y8 head I'm go a swap that then check the z6 head out
Old 08-10-2014
Rhonda1's Avatar
Rhonda1 is an unknown quantity at this point
Your car rev sounds odd. The click clack may be your IACV engaging and disengaging. Test by disconnecting the harness and see if the sound goes away. It wont hurt your engine but will make the idle fluctuate. I also noticed you do not have a CEL "ON". You have a swap on the head that is a Z6 so I would check and see what ECU you currently are running. Does your car drive with hesitations/sputtering at low rpm when taking off?
Dorval Andre
06-26-2015 10:03 PM
Reverb2005
06-26-2015 06:22 PM
civicns
05-08-2015 09:49 PM
Dorval Andre
05-01-2015 09:37 AM
rcolosi
04-29-2015 07:48 PM
Quick Reply: I can't figure out clicking noise
