low RPM hesitation
BACON
Rep Power: 0 low RPM hesitation
So I just bought a '95 Civic EX 1.6l manual. I get a slight hesitation between 1500 RPM and 2500 RPM. I'm going to start with a tune up when I change the timing belt and water pump to see if that fixes the issue.
It's weird it actually felt like a slipping clutch when I first drove it, so I pulled the trans and the clutch was fine with just a little bit of un-even wear. I got the flywheel resurfaced and replaced the clutch and it still does it. But now that I know the clutch is good it seems more like a mis-fire but no codes and as soon as it hits 2500rpm there is no hesitation.
I was thinking maybe the timing is just off or something simple but any advice would be great.
BACON
Rep Power: 0 Re: low RPM hesitation
Tomorrow morning when I'm no longer pissed off about doing the clutch on this thing I'll take some time to check spark, fuel pressure and anything else I can think of. The CEL has not come on so I'm assuming there aren't any codes but I suppose I could hook up the jumper and see if anything comes up.
BACON
Well the simplest solution is usually the last thing I try. I checked the timing which was off a little so I adjusted that. Then I pulled the plugs and the gap was at .065 so I fixed that and took it for a drive and no more stumble. Now I'll just do a tune up since it obviously needs it.
Also does any one know what sensor this is? I broke it loosening the dizzy.
mrohitredd
05-30-2015 06:51 PM
mrohitredd
18
05-14-2015 07:35 PM
dooner24
04-14-2015 07:51 PM
answers to all these frickin turbo, nos, and super questions- im RANTING!!!!!!!!!! PLEASE READ!!!!!!
pinkytoe
01-08-2002 06:05 PM
Aznnp77
12-13-2001 04:03 PM
