Hood latch issue
Rep Power: 0 Hood latch issue
I just put on a new hood on my 1991 civic dx (original unlatched on hwy) . I was checking to see if things lined up properly and latched. I went to pop it open and thre lever broke. How do I pop the using the existing cable.
Rep Power: 787 Re: Hood latch issue
you would need to cut around the cable to remove the plastic covering, then pull the metal cable part with pliars. you will have to replace the whole thing anyway so cutting it isnt a big deal.
Rep Power: 0 Re: Hood latch issue
I am not sure about yours, but my son's has a ball that is similar to the cable style you would see on a clutch or throttle cable on a motorcycle. We can pull on that ball on the cable end by hand. If it is harder, you should be able to pull on the cable end with pliers. That is if the plastic handle is the piece that broke and not the ball off the end of the cable. If it was the ball end, you will have to cut the cable jacket back as gearbox described. You should then be able to pull on the actual cable with pliers or vice grips.
geoffm1234
Exterior DIY
06-03-2015 08:18 PM
Ezql
05-26-2015 11:46 PM
crowtoo
05-11-2015 06:50 PM
insan
01-27-2002 07:36 PM
