95 si hatch wont stay on
Old 04-16-2011
garza1553's Avatar
garza1553 is an unknown quantity at this point
my 95 civic si has been acting up the last couple of weeks. first it would take a couple of times to start it then it finally stopped working. changed fuel filter and fuel pump still nothing i pulled the spark plugs they were dirty and so i cleaned them up they were only a couple months old. still nothing after a few trips to auto zone i ended up buying new plugs and it fired right up. then a week later went did again changed the plugs but it still wont stay on it cranks over but then turns right off. any suggestions?
Old 04-16-2011
BLEGAN's Avatar
BLEGAN is an unknown quantity at this point
Re: 95 si hatch wont stay on
have you checked all your connections? battery wires and whatnot. i'd say more than 50% of the time i've had starting/electrical problems, it was the wiring lol
i just really really like that smiley
Old 04-16-2011
Trance Addict
MelJ's Avatar
Did you actually check to see what exactly was on the plugs? They can tell you a lot about your engine. Oil fouled plugs usually mean you've got a gasket leak, which is an easy fix. Fuel fouled are from a flooded engine. Had that happen to me recently.
Old 04-23-2011
xylerium's Avatar
xylerium is an unknown quantity at this point
Do you hear the fuel pump kicking on when you turn the key to "on"? Do you hear a relay click when the Check Engine Light goes off? You'll have to turn the key to "ON" (not start) and wait for the click ...
If you don't hear this, it's probably your main relay (symptom: car will turn over but not start, and you don't smell gas from the exhaust)
UltraHDGames
06-08-2016 05:16 PM
Crazygrlinak
10-08-2015 05:06 PM
Solo Flow
10-04-2015 07:52 AM
BBrosario
09-17-2015 07:51 PM
yyyktk1
09-12-2015 04:02 PM
Quick Reply: 95 si hatch wont stay on
