My car wont Rev Past ~3k RPM's
JDM
Rep Power: 0 My car wont Rev Past ~3k RPM's
Whenever I try to go past ~3k RPM's in any gear it wont let me and it feels like it doesn't have as much power as it did the other day. For example, in 5th gear I can only go 65 top and if i try to accelerate past 65 mph it makes a noise like its redlining, kind of a repeating revving noise. I tried replacing the spark plugs and i put on a new oil filter but it still continues doing that, HELP !!!
It's a 94 Civic EG Hatch with a b18b1 swap.
Trance Addict
Re: My car wont Rev Past ~3k RPM's
If you're flooring the gas pedal and it's getting loud and the car isn't going anywhere, it's your clutch. Do you smell anything when this is happening? What exactly is the tach doing when you accelerate?
I second the Clutch, esp if it's original...what's this world coming to when you can only get 17 years out of a clutch
I drove a Dodge Colt with a bad clutch in High School...Rode the thing until I couldn't move it...Lost 1st, 5th, Pumped it in 2nd off the line and then it would be an adventure to get it into 3rd. It feels like you've lost 2 of your 4 spark plugs..
JDM
Rep Power: 0 Re: My car wont Rev Past ~3k RPM's
Also, the check engine is on, but its been on since the motor swap and I put about 50k miles on it so far and it just started doing this. This is the third time it has done this and usually it stops after it sits over-night but this time it isn't stopping. I have no idea what it is.
ALSO, it shifts fine into each gear & doesn't grind or pop out. And I can rev it up as soon as i start it but when I let it drop to idle, it won't let me rev the engine up past ~3k rpm's
Trance Addict
Well, if you can, get the codes and we can probably help narrow it down more. That'll give the forum guys something more to work with. Someone may have an answer right now, but pulling the DTC(s) is always a good place to start.
Received 1,440 Likes
Rep Power: 338 Re: My car wont Rev Past ~3k RPM's
yeah, just one light, but there might be more codes in there now. sounds limp mode went in for whatever reason?
Note: important info like this should be on the first post, not second
JDM
Figured out the problem, one of the fuel injectors was badly corroded and so i replaced it and the spark plug wires and now it runs like a pro again. Thanks to all of you who helped.
good to know all is good again!
I suppose the injectors would not throw a cel, so...
Trance Addict
The Jeep we're using in our fuels class throws codes for injector issues. I guess some cars don't though. Glad to hear everything is good! I'd suggest changing all the injectors though. My teacher said it's a good rule of thumb that if one goes the others are probably close to going as well. I didn't even think you could buy a single injector. Lol.
i have the same problem but mine has an ls head sittin on a b20 block i just got the car this past week and am already having problems and i need to fix asap plz help
If you punch it in 5th and all it does is rev, then it's definitely your clutch. That's the first sign that it's going. I suggest that you find a highly recommended mechanic to do it on a side, because any shop will absolutely rake you to replace it. Good luck!
I have a 03 lx 5spd. And a similar problem code sais misfire in cyl 1234 but i have perfect idle and normal accel. but when get to 4k rpms in 5th it acts like a govenor kicks in and wont accelerate until its back under 4k it also does it in fourth gear. And im not punching it, highway coasting at 80 if i go past 83 engine stops until it gets under 80.
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
mistahlorax13
21
11-18-2015 12:47 PM
NROD315
09-23-2015 03:46 PM
Juanb24
09-15-2015 12:39 AM
