new to the honda world and need major help!!
Rep Power: 0 new to the honda world and need major help!!
alright civic smarties,
1991 civic hb si
1.5 L
pulled it into the garage, changed the carpet, and all of a sudden it cranks but won't start??? WTF!!!
about a month ago changed head gasket, water pump, distributor cap, rotor, wires, plugs, timing belt. everything working good, then poof. nothing.
so started doing some testing, coil is good, bought a new one just in case, still nothing. tested the ignitor at autozone, came back good. main relay is turning on, fuel pump turning on, all dash lights doing what they are suppose too. put ohm meter to the correct terminals, got oem specs. So now im really confused and don't know where to go next to get the spark. checked all my fuses, and they are good. ECU is flashing a code 6, which is temperature sensor, changed that out too, and still shoots a code 6. So that is a question also. Is there a way to reset that, not sure.
Any help asap would be greatly appreciated. It's my daily commuter, which i commute 30 miles one way. Using my big v8 truck, is killing me in gas, and i miss my honda. So thanks for any advise!
1991 civic hb si
1.5 L
Rep Power: 0 Re: new to the honda world and need major help!!
ok so pulled the plugs:
#1: plug is black with what seems to be oil/gas around the threads
#2: plug is very black but dry around threads
#3: plug is black with oil/gas around threads
#4: plug is back with oil/gas around threads
so if oil is getting to the plugs will this also cause the wires to foul as well therefore resulting in no spark?
Rep Power: 210 Re: new to the honda world and need major help!!
-check timing again
-check if plugs are gaped right (just because it says "pre-gaped" doesn't mean it will get to you gaped right)
-check if air filter is clean
Kenny the Ricer
How to read spark plugs
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
If oil is getting into the sparkplugs, it maybe a number of different reasons, someone will probably drop in this thread with help
Wires should not be fouled due to oil getting to spark plugs
i have put a timing light on the engine and cranked it. no light flashing??? timing gun is good, still scratching my head. Im totally lost. When i changed the head gasket, and looked at the valves, they seemed to be ok with the common look i guess of an engine with 194,000 miles. but if i have oil leaking then maybe i overlooked something. would that cause the no spark problem? cylinder walls were in good shape, should mention that. pistons and rings didn't look like they were damaged. Like i said, been driving it for awhile after i changed all that stuff, then nothing. Thanks for everyone chiming it, and throwing out suggestions. I will try anything and everything you guys throw at me.
Kenny the Ricer
According to this website:
http://www.tegger.com/hondafaq/oilyplugs/index.html
I would suggest looking at those rings, and replace them if neccessary
The rubber donuts eventually get old and stop sealing, letting oil seep into the spark plug holes and puddle there. The cure is replacement of all four (or six), along with the valve cover gasket itself (themselves) at the same time. It's an easy project for anyone who's done more than just oil changes.
thanks kennykid2002. that's a great link. i didn't replace those orings when i did my head gasket. probably the reason for the fouled spark plugs. Just entertain my understanding, or lack there of, the oil fouls the spark plug, understand that, but why no spark down my wires? is fouled plugs the reason i can't get a spark down the wires?
Kenny the Ricer
Im not sure if oil in the plugs will effect the wires, but to entertain you, persay, you can change them for peace of mind.
Mostly, I would replace those O rings, and clean out any residue oil inside, charge the battery and see if i could get some sort of spark
Oh, and check your grounds as well (engine to chasis, tranny to chasis, chasis to neg)
thanks for everyone's advice. this is a great forum. honda enthusiast sure know how to stick together. anyway, found the problem. main relay was bad. even though it sounded like it was working and everything was functioning, decided to resolder and it fired up on the first shot. redid the timing as well, was off just a little. runs like a champ. did end up changing out the rubber gaskets under the head cover for the plugs. hopefully this keeps the plugs alittle cleaner. the engine is getting tired, so i believe i might be getting a d15b vtec for it in the near future. it is my daily driver so i would like to go bigger and newer, but kinda need a quick swap solution. anyway, thanks again for advice, especially kennykid2002. any suggestions on the swap, im all ears.
Jon-Ohio
06-30-2018 08:10 PM
pheaton
05-04-2015 08:26 PM
jessicakaybby
04-20-2015 12:11 PM
Bartkat
20
02-19-2002 01:29 PM
