1998 LX Problem AFTER PROBLEM, Coolant Leak Under Car
Old 06-20-2014
CivicLXTillDeath
7sugar's Avatar
7sugar is an unknown quantity at this point
Post 1998 LX Problem AFTER PROBLEM, Coolant Leak Under Car
So I bought this car from a friends dad,(450$)haha It had a blown head gasket and was overheating all that good stuff. I went in replaced the head gasket and did the timing belt, also the exhaust manifold was cracked i welded that, I didnt replace the water pump but now I'm thinking i should have. All said and done the car runs. Now, i drove it to my house from theirs (20miles) put 50 on the car so far driving around and notice coolant leaking out under the car near the oil pan.. Checked all hoses and deemed them fit.. I just bought a new water pump but the coolant is leaking somewhere under the intake seems like its coming out near the oil filter.. I just am worried about driving it around before i fix this leak.
its a 1998 honda civic lx with 163,xxx on it. What could be causing this leak? I bought a new water pump heard it may be thermostat housing/gasket or the little metal tube getting corroded and busting an o ring, but how could i pinpoint? any advice would be great
it seems like after driving n running a while the leak is worse. My parts are here today hopefully so ill be posting pics along the day.
Old 06-20-2014
Re: 1998 LX Problem AFTER PROBLEM, Coolant Leak Under Car
You need to get in there and see where the leak is coming from.
Get under it if you have to to find it.
Fill the radiator up and see where it leaks out. Put a funnel in the radiator neck?
Old 06-21-2014
CivicLXTillDeath
7sugar's Avatar
I looked more today gonna do repairs tomorrow, it looks like its coming out of my valve cover maybe? i got under it and couldn't tell the other day stumped me and a couple buddies but i was parked on a hill today and it was dripping off the frontside, so seems to be coming out of somewhere high up.. not the lower hoses or housing
Old 06-21-2014
Antifreeze cannot leak out of the valve cover.
Keep looking.
Fill the radiator.
Put the cap on
Squeeze the radiator hose to force the leak to squirt out?
Keep looking.
Xuhme
21
08-07-2023 03:40 PM
mattdoc
03-14-2017 12:10 PM
LionSpratt
01-29-2017 11:07 PM
CascadiaBlue
04-18-2015 09:13 AM
jackoncruzpr
04-16-2015 12:29 PM
Quick Reply: 1998 LX Problem AFTER PROBLEM, Coolant Leak Under Car
