Instrument lights don't work
Old 01-08-2011
boltjames's Avatar
boltjames is an unknown quantity at this point
Bought a 200 civic and the interior instrument lights don't work. The previous owner has installed an aftermarket stereo and I heard this may have affected the circuit. Has anyone had the same issue and how do you fix it? The previous owner says the switch on the turn signal has to be replaced but the exterior parking lights work and headlights. The 7.5 amp fuse is good, already checked voltage there.
Old 01-08-2011
CraigW's Avatar
Re: Instrument lights don't work
The 6th gens ( if 2000 ) had some issues with the dimmer controller unit located behind the ****.
If 2001...well...
Old 01-10-2011
critter210's Avatar
critter210 is an unknown quantity at this point
Here's a response from member RonJ " Sounds like a bad dimmer switch. Carefully pry the switch out of the dash, unplug the connector, and then install a jumper wire into the free connector in such a way as to connect the Red and Black wires. Do the lights now work" This how I repaired the lights on my 99 after I installed a new radio. You'll need to check the radio first and make sure the orange/ white wires are not connected.
Old 04-03-2012
imatuner2's Avatar
imatuner2 is an unknown quantity at this point
What if they are connected and you jump the red n black?
Old 05-14-2014
bsm760's Avatar
bsm760 is an unknown quantity at this point
I had the same issue in my ek, I hit the dash board right above the dimmer switch and I came on but every time I hit a bump hard it will go out...check ur fuse wth a test light note sometimes it will light it if the fuse is blown juss take it out juss to insure urself kause that happened to me and it was juss a fuse lol gl
CarStuff
12-06-2020 12:52 PM
roverben
01-21-2019 05:16 PM
ORskier
05-03-2015 12:54 PM
tylerginevan
04-27-2015 12:29 PM
smmahan
04-15-2015 08:17 PM
Quick Reply: Instrument lights don't work
