HID headlight not working?
Rep Power: 0 HID headlight not working?
I just bought a 2000 Civic Ex Coupe, with HID headlights, not sure what brand, and the passenger side headlight isn't working (drivers side is working fine) and the high beams aren't working (not sure if it has them). I don't know what's wrong with the headlights, so i took a picture of that transformer/electric box thingy attached to the headlights (attached)
Received 1,144 Likes
Rep Power: 485 Re: HID headlight not working?
That little electric box is the ballast/igniter for the hid bulb. Quick question, do you have your setup wired directly to the factory headlight harness or do you have the ballasts receiving power through a relay harness? I'm willing to bet you don't have a relay harness and your passenger side isn't getting enough power, a common problem encountered when *not* using a relay harness.
Also, you do have high beams anymore, unless you did a bi-xenon retrofit. In that case, your high beam would consist of the low beam staying on and the shield on the HID projector dropping.
Rep Power: 0 Re: HID headlight not working?
I believe it's the factory headlight harness, but I'm not sure, I didnt do it, the headlights were in the car when I bought it (the only thing i've done so far is raise the idle because it was too low). How would I tell the difference between the factory headlight harness and an aftermarket one?
follow the wires coming out of the ballast, not the ones going to the bulb, but the power supply ones. If the power supply wires lead to the factory H4 harness, then you have no relay harness.
Alternatively, you can see if there are any obvious aftermarket connections coming off the battery or fuse box to a relay.
I've figured out that there is something wrong with the ballast. I am now wondering how hard it would be to switch from the HIDs that are in it to the HIDs that have high and low beams. how hard would it be to make the swap? Do I just have to buy the bulbs and plug them in? Or do I have to replace the entire system? How much labor would be required, and how much would it cost? I am also looking to replace the headlight covers (they're clear now, looking to get black ones) and am wondering if I have to get ones that are made to go with HIDs.
so, I have had enough with this headlight ****, so instead of selling the car (like I usually would, I've sold cars because the power locks didn't work) I decided to buy a whole new system, because I found a Bi-Xenon Hi/Low beam system on amazon that's usually $250.00 on sale for $60.00 with free shipping (Link: ). I will find out in about a week if these work! I also figured it'd be better to do this being that the replacement ballast is $85.00, and I really need high beams where I live (very rural area, lots of fast, rural, dark high way driving with no other cars to provide light)
yeah, still not gonna solve your problem. The HID bulb is still gonna act as a single filament bulb. I will give that kit one thing though; not many kits out there come with casper shields for use in reflector housings.
The only way to get a high beam out of HIDs is to have a bi-xenon projector setup (high beam activation drops a shield in the projector). I've also seen some HID bulbs out there (back in.. 2005... not sure if they're made anymore) that have a small halogen bulb protruding from the base that acts as a separate high beam.
A proper bi-xenon HID retrofit will give you the high beam you desire, and theretrofitsource.com (hereafter "TRS") makes a projector that literally takes no more than an hour to install into OEM H4/HB2/9003 housings. However, you will not be able to use the current HID bulbs, nor the new ones you've posted, with the projectors to which I'm referring.
edit: if you decide to visit TRS, look up the "morimoto mini" projectors. Those are the ones you'd want to get. They come in two flavors: H1 and D2S. Small structural differences, but the major difference is the bulb they use. The H1 version will use a bulb that's a bit easier to find, as it's a rebased HID bulb to fit into H1 headlight housings. The D2S version will allow the use of higher quality (albeit, more expensive) bulbs. For universal ballasts, the latter version will require an amp to D2S conversion pigtail, whereas the former option will act as a plug and play with your current ballasts. I can personally vouch for the quality of TRS's products and customer service.
I have a hi/low H4 HID kit on my 1999 Civic and the high beam function works rather well. There is a lot of leakage but when you turn on high beams, the solenoid sucks in the bulb and the light reaches a lot farther. I have the anti-glare shields removed.
BTW, Xentec sucks! They are the cheapest brand, they wouldn't ever be $250.
DDM tuning, or RTS are good brands.
So are the DDM Tuning 35w HIDS good or bad? I just want a brighter light and don't want to pay a lot of money but yet don't trust those $20+ kits off ebay. I have a 2006 civic that has shitty lights and just want to replace the high beam..any suggestions?
BTW I'm from Canada so I have to keep an eye out for shipping costs too.
I put in the kit that I bought, and the Hi/Low function works perfect, and they've worked since I put them in a few weeks ago, I use the high and low beams every morning on my way to school and every night on my way home from work, and they are insanely bright, and you can definitely tell the difference between high and low.
DDM or 'The Retrofit Source' are reputable, DDM being cheaper.
intensity
05-12-2015 10:43 PM
ORskier
05-03-2015 12:54 PM
