Smooth Suspension w/ Very Low Clearance.
The name is Jose, got a 98 Honda Civic Ex, wanted to ask you guys if you can recommend any smooth yet has very low clearance suspension. At the moment i have tokico white struts w/ megan racing springs in the front, and the rear i have full coil over skunk2 pro S series. Rides okay with this suspension but i have a clearance on the front that's very limited. As well as front/rear Godspeed Camber kits.
I'm thinking of getting a new setup hopefully next month and was looking at function-from type 1 and 2, yet i hear they have a very low clearance and smooth, I'm pretty sure their other coil overs with lower clearances and smoother when driving. would appreciate it if you guys have any recommendations on other coil overs and if you can post pictures of your car with the suspension on.
Thanks,
LuckysEk98
Thanks,
LuckysEk98
Prelude Owner
Re: Smooth Suspension w/ Very Low Clearance.
Not many people on here with that gen civic.
F&F have a pretty high spring rate if I remember correctly. The ride will be firm. If you want s smoother ride that can go really low I would check out Ground Control paired with Koni yellow shocks. You can custom order spring rates and the Koni's have a great range of lowering.
I'm sure you can find more info online and pics of other people with GC/Koni setup.
Ok i will give that a shot, ill look more into the Ground Control w/ Koni. thanks for helping me out.
CraigW
08-18-2015 07:06 AM
adamdrives
15
08-08-2015 08:53 PM
alxz310
07-30-2015 12:18 PM
