Question on lowering 96ex coupe
Rep Power: 0 Question on lowering 96ex coupe
i'm about to lower my 96 ex coupe its got about a bill 65 for miles (165,000) should i replace all the bushing?
ive got 1.5 lowerig kit
camber kit FR should i buy a the rear camber kit too
since i have the car apart i want replace everthing that is needed
Rep Power: 787 Re: Question on lowering 96ex coupe
at the very least, you need springs and upgraded shocks (that are rated for a lower drop, not stock) and a camber kit + alignment. the rear camber kit is the most important. and dont forget alignment when everything is installed. if you want to prevent future problems, front LCA bushings and sway bar endlinks should also be upgraded.
Received 1,440 Likes
Rep Power: 338 Re: Question on lowering 96ex coupe
96 would need to have front/rear camber kit?
oh yeah i forgot pre 2001 civic has a different suspension. adjustable shocks prolly arent needed, esp if you will not be adjusting them. daily driver springs and shocks are fine. the tokico HP (blue) is pretty good for up to a 1.5 inch drop if they make it for your car.
and visually inspect the bushings for cracks/tears.
Note: camber kits for these gen are complete LCA, so they should come with bushings.
h4ldol
06-03-2015 03:26 PM
jdawgzcivic
05-20-2015 08:14 PM
oneheadlight
04-29-2015 11:30 PM
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
