Bench test a TPS?
Old 05-09-2012
buckwheat1988's Avatar
buckwheat1988 is an unknown quantity at this point
Bench test a TPS?
I just changed my TPS on my 2000 civic and wanted to bench test it for the hell of it.
Old 05-09-2012
Re: Bench test a TPS?
Cool story, bro.
Ok. Carry it to the car.
Plug it in to the correct harness connector.
Connect a voltmeter to battery ground, and probably the center wire of the TPS sensor, red/blk.
Turn the key on.
Read the meter.
Work the sensor, watch your meter.
Normal operating range when installed on a throttle body is roughly 0.49v to 4.59v.
FYI, the new TPS should read .49v on the output wire with the throttle closed.
amrhamed
08-07-2015 11:39 AM
Martinez8o5
07-31-2015 10:58 PM
DerbyDad03
07-27-2015 11:34 AM
07-12-2015 11:54 AM
Quick Reply: Bench test a TPS?
