97 civic crank no start has fuel spark and timing is on
Rep Power: 0 97 civic crank no start has fuel spark and timing is on
I noticed a slight hesitation the other night when applying throttle. Next morning it seemed to get worse every time I applied the throttle past about quarter throttle, it would under quarter throttle Rev all the way up slowly though to red line if I wanted. Eventually got so bad it stalled out now it's crank no start. I have decent spark, swapped out the icm and coil anyway. Timing is on. I'm getting fuel. It won't start with starting fluid either. I replaced the iac and swapped a different throttle body and still nothing. All stock manual transmission p2p ecu. Please help
Re: 97 civic crank no start has fuel spark and timing is on
Re: 97 civic d16y8 crank no start
You verified both mechanical and ignition timing? Tested the mainn relay?
Rep Power: 0 Re: 97 civic crank no start has fuel spark and timing is on
You verified mechanical and ignition timing? Did you remove spark plugs, inspect for fouling and smell for fuel getting into cylinders? Main relay tested? The initial throttle response issues sounds like a failing/weak fuel pump or clogged filter. Did you happen to get gas a bit before this issue started?..maybe water in gas.
Did you try starting it with pedal to floor (WOT) in case it may be flooded?
I helped a friend with his '04 VW Passat and he had a crank/no start issue. We checked fuel at rail and it was present but couldn't get it to start. A day later he checked fuel at rail again and it wasn't present. He tapped on fuel pump with a hammer and it worked again but still wouldn't start the engine. In the end it turned out to be a weak/failing fuel pump with low pressure. He replaced it with a used one and it's been fine for past six months. Not saying this is the issue but unfortunately, without a fuel pressure gauge it's only a guess that it has proper pressure. One way to test without a feul pressure gauge is to pull injectors and spray them into a bucket.Watchh for spray pattern, flow and timing.
Hopefully, a real mechanic (Ezone or others here) will reply soon. Just for future reference and something you may already know a '97 is a 6th gen (96-00).. you posted in the 1st-5th gen. Not a big deal though because unlike some of the douchebags on a site with the initials H.T., you won't get berated for it.
Threads merged.
Replied to one thread before I read the other to see my question was already answered.
Someone needs to berate belittle and chastise OP for screwing up posts on his first day here, so he feels welcome. Tsk, tsk. Shame on you! Where'd turd go?
Real mechanics get all greasy and dirty and stuff, that's just not my bag.
So I'm not a real mechanic.
But I did stay at a Holiday Inn Express last night....
Where? How do you know it's getting into the cylinders?
Are the spark plugs wet with gasoline, or perfectly dry?
How large an air gap can the spark jump?
Verified and proven good parts were used?
Cam timing? Ignition timing? What?
ECM grounds on thermostat housing clean and tight?
Got compression?
Fuel is really gasoline, not sabotaged with diesel, urine or sugar? LOL
Got backpressure? Clogged exhaust/cat?
I'm getting fuel.
Timing is on.
Got compression?
