Reseat the camshaft seal without removing timing belt?
Rep Power: 0 Reseat the camshaft seal without removing timing belt?
Hey, so I just finished my timing belt head gasket job on my SOHC D16Y7
Only problem I've noticed is that I may not have seated the camshaft seal appropriately because it's leaking oil, seems like from the bottom. Prior to the job it was sealed fine, but I had to take the cam off to get the head milled. I'm really hoping to do this without suspending or removing the timing belt. Since it's already on the camshaft, I was thinking about removing the rocker arm assembly and cleaning the surface and then reseating it, but I'm not sure how to appropriately seat it.
Thanks.
As a side note, it'd be cool if someone just made a 2 piece camshaft seal so you didn't have to go through a bunch of **** to replace it lol one that slides in on the bottom and then has a hook inside to hook up with the top.
Thanks.
Re: Reseat the camshaft seal without removing timing belt?
Many don't get it installed deep enough and leave the outer seal lip hanging off the end of the area machined for the seal on the cam.
Rep Power: 0 Re: Reseat the camshaft seal without removing timing belt?
Ah, I see, I probably just seated it wrong. I was focused on the aspects of the other parts of the jobs and just overlooked it.
What sealant do you recommend/used in the pictures? I've got RTV high temp gasket maker, but I don't think there's a way for me to apply that appropriately.
Other choice might be an aftermarket seal that isn't right at all.
I sometimes use an anaerobic sealer, other times I use Hondabond. Depends on what's handiest at the time.
In response to your first post, I ended up having to reassemble the rocker arms and adjust the valves anyways, which would be tedious to do again, but if necessary, it's better than taking off the timing belt.
Ey, appreciate the help homie. I'll post up when I do it tomorrow.
So I attempted to reseat it. Only problem is I busted a bolt on the rocker arm assembly. So the leak is better, but it's still a drip. About a drop every ten seconds while the engine's running. I'm trying to get this car ready to sell for my girlfriend and I'm an honest man and wouldn't post a car without this known. Oil leak is a red flag for a lot of people regardless of severity. At best, it's a price adjustment. Is there a way to seal it externally? I really don't want to deal with removing the rocker arms, let alone the harmonic balancer again.
How you break one? What were you doing when it broke? Where is it located?
Dig it out and fix it. A left-hand drill bit can sometimes work miracles LOL
Have you run it without the covers so you can actually watch for the true source of the leak?
It's the little 10 mm one on the driver's side end of the rocker arm assembly closest to the cab, not the actual larger 12 mm cam bolts. I broke it trying to torque it down to 9 ft-lbs. It wasn't torquing and then it just snapped in half.
I've been running it without the upper timing cover and you can see the trail start from the bottom of the cam seal.
Is that cap pushed completely flush against the surface of the cylinder head?
Didn't find a good pic in a quick search.
Yeah, it still has one bolt and 2 of the 12 mm cam bolts supporting it. I got it pushed in before the lip, but would it hurt to just shove it back even further?
Can you tell if it's leaking between the camshaft and seal, or if leak is around the outside diameter of the seal?
