Continues high reving
Rep Power: 0 Continues high reving
Hi guys I just made an account and I just got a 97 honda civic coupe. I got it for 600 bucks for something to work I do not know a whole lot but I love working on cars and hoping some of you can help me out along the way. The civic has a continuous high idle from the moment it starts up and the young guy I bought it from only had it for a few months bought it off some old guy and neither of then did much with it so I think all the problems started when a young kid wanted to rice it out. But when he put the air intake back on he never conceded the air hose from the intake to the head and there is a lose hose the runs above the fuel rail and down and I have no idea where that is suppose to go. So if you have any idea what I am talking about please give me some ideas . I am going out to take a look at it as I have only looked at it for about 10 mins in the dark last night when I got the car . I'll take some pics and see if I can show you what I am talking about.
Received 1,148 Likes
Rep Power: 485 Re: Continues high reving
Pics would help. Does rpm maintain high at idle or does it settle down to ~700 ish after some time?
6th gen Civics always (normal) idle high for the first few minutes and then drop to around 650 with no load (a/c, headlights etc..). If it idles high continiously remove the throttle body and clean it with throttle body cleaner. Can use a tootbrush or small brass brush and clean both side of throttle blade and body. Good time to remove and clean IAVC too (youtube). Other than that search for vacuum leaks. Check vacuum line that runs from cruise control (if equipped) to intake manifold (facing firewall).
Rep Power: 0 Re: Continues high reving
I removed the air intake throttle and cleaned aivc and air intake blade it still idles high and then dropped then high then dropped and then all of a sudden it started gushing out coolant from the upper rad hose. Loud spews about 3 seconds long each .
As far as the coolant leak did a hose or clamp come loose?
Overheating?
I didn't want to be the bearer of possible bad news.
Seems like the reality with buying any used car under $4 to 5k is it will take another $500 or more to get it in proper operating condition. When I was younger I had a lot less knowledge of cars yet, most of the cars (mostly late 70's Toyota's) I did buy served me well and not a lot repair needed. I know more now but, the cars I've purchased in the past decade have cost me more after purchase. Most recent purchases have been 5th and 6th gen Civics..lol. I blame it more on Craigslist artificially inflating values and increasing the sleaze factor of sellers.
Even with the repairs older Civics look better and are more fun to drive than Toyota's from the past two decades.
