00 LX overheating, added coolant
Rep Power: 0 00 LX overheating, added coolant
my 00 LX is running very hot, stays cool on start but around 25-30 heats up. at 40-45 the gauge will hit the H and i have to pull over. I can hear the radiator bubbling. Checked and it was very low on coolant so i got it some and filled it up but it is having the same symptoms. gonna take it to a mechanic tomorrow i just didnt know if anyone had knowledge on what this would be/ ballpark on its maintenance cost
Received 1,148 Likes
Rep Power: 485 Re: 00 LX overheating, added coolant
check for signs of coolant leakage: wet coolant somewhere, or dried coolant (will appear white, powdery-looking caked on stuff) and try and trace a leak. Worst case scenario, head gasket is leaking, causing coolant loss
Simple gasket change (e.g. water passage gasket, random coolant system o-rings), it'd be much more worth it to DIY, and I'm sure you can find DIY guides here, or ask for someone to give DIY instructions and pictures, if possible. If head gasket, you'd be looking at probably ~$1500 for the job.
Rep Power: 0 Re: 00 LX overheating, added coolant
Received 1,126 Likes
Rep Power: 191 Re: 00 LX overheating, added coolant
Its possible but you have to figure out where its leaking from first,
If you're in a snowy area parking over snow can help figure out where drips are originating if its dripping. If its evaporating before it can hit the ground look for chalky deposits like riceboy said. They usually are the same kind of colour as the coolant, green/blue or sometimes yellowish
Those engines have head gasket issues too, so watch out.
