1999 Civix LX it is stalling
Rep Power: 0 1999 Civix LX it is stalling
I have a 1999 Civix LX it is stalling and I have read all of the threads and performed all of the repairs below.
Replaced
distributor
fuel pump
air filter
fuel pump filter
fuel filter
TCCP
Can someone PLEASE direct me to my next move?
Replaced
distributor
fuel pump
air filter
fuel pump filter
fuel filter
TCCP
Re: 1999 Honda Civic stalling issues
You will get more responses if you start your own thread.
Re: 1999 Civix LX it is stalling
Moved to a new thread
What's a TCCP?
Correct move is to be observant at all times. Know what is normal, so you can identify when something is not normal. Then test to figure out why.
What does or does not work at the time of the stall?
Usual suspects:
Ignition switch fails: no warning lights come on when it stalls out, dash is dead and dark just like someone turned off the key. Warning lights come back on when you touch or jiggle the key. Lights may flicker as you turn the key through bad spots in the switch.
PGMFI main relay fails: Controls power to the ECM and the fuel pump. Usually causes no start condition, but it can also cause random stalling.
Could cause ECM to randomly drop dead (check engine light does not come on for bulb check) or the fuel pump randomly quits, depending on how the relay unit failed.
Usual suspects:
Leo1990
06-15-2012 07:31 PM
Carnivorous18
15
06-06-2011 07:53 PM
brobo
10-03-2010 11:14 PM
