96 civic idle problem
Rep Power: 0 96 civic idle problem
hi my 96 civic just all of a sudden have a weird idle problem when its in park. sound like the engine is reving up and down. but when im in D4 it doesn't make that sound.
Re: 96 civic idle problem
yes correct the iacv i just cleaned mine with carb cleaner. was doing the same at idle. now seems to be fine. that part is not cheap cleaning is your best bet
Rep Power: 0 Re: 96 civic idle problem
I tried looking for the IACV but I cant find it, I googled where it located but the pic is different from my engine. I have a intake box on top of my engine and all the pic doesn't have a intake box. any 1 can help me figure out where it located? people say its behind the intake manifold but couldn't find it
how to remove the engine filter box?
A wire connector on the sensor, a hose from the valve cover, and a bolt facing the firewall-- 10mm socket
I don't remember if there is a clamp around the throat of the throttle body or not. I know there is on a later car, but it's been a damn long time since I've had one of yours apart.
The picture I saw showed one bolt facing the back, but I'm not gonna swear that's all there is. There may be at least one on the front too? Get a flashlight and look around.
I think it's only one bolt, and the clamp around the round part on the bottom. Yes there is a clamp like a hose clamp.....might be 8mm socket, might be 10mm
sk9000
02-11-2016 04:11 PM
Gdinsky
03-01-2013 12:10 PM
rajbirrehal
02-25-2011 08:53 AM
Aznnp77
07-21-2006 03:41 PM
Nytelandz
04-08-2006 09:49 AM
