Loss of power, smell of gas honda civic ek4 2000 year 1.6 vti
Rep Power: 0 Loss of power, smell of gas honda civic ek4 2000 year 1.6 vti
Hi,
noticed idle was a bit rough, replaced plugs still same, HT lead seem ok all cylinders appear to be firing....
but i smell petrol/gas when driving and the acceleration seems to have a huge lag
i drive a honda civic ek4 2000 year 1.6 vti 50k miles on the clock
its drinking fuel and using some oil :/
any ideas what the issue could be?
Re: Loss of power, smell of gas honda civic ek4 2000 year 1.6 vti
Hi,
and/or primary o2 sensor: http://www.primechoiceautoparts.com/...-Symptoms.aspx
CEL on? Did you check for fuel leaks?
In my area (rust belt, USA) we see cars that old rusting out brake and fuel lines under the car. If it's really losing fuel fast, see if there's liquid pouring out?
Rep Power: 0 Re: Loss of power, smell of gas honda civic ek4 2000 year 1.6 vti
im in the UK this is EU model and i think it may be my manifold as its getting loud
i had a friend look it over but the cat does look pretty rusted, no leaks tho....
i can see no liquid pooring out
no engine light, but will check 02 sensor
Hi again,
had the manifold cover off, discover 1 bolt is lose on right hand side, and another is missing the nut!
Lots of black carbon/soot build up around ill post a few pics
gasket has probably gone also, taking it to the shop tomorrow fingers crossed a couple of bolts and a new gasket!
Ah, it sounds as though you have been smelling exhaust fumes rather than raw gasoline (petrol).
Pr0n1s
04-30-2015 03:08 PM
jessicakaybby
04-20-2015 12:11 PM
dooner24
04-14-2015 07:51 PM
