97 Civic Oil Plug Problem
Rep Power: 0 97 Civic Oil Plug Problem
My sister recently bought a 97 Civic and attempted to do her first oil change on her own. Apparently the previous owner lost the original oil plug because there was a universal drain plug installed. The plug has 2 metal wings that fit into the oil pan to grab the pan from the inside to hold plug in place.
I am not sure if my sister unscrewed the plug so far as to cause the inner wings to fall off or if she over tightened the plug causing the wings to break off. Either way, there are now two metal bits stuck inside the bottom of the oil pan. I have already obtained a new threaded plug as a replacement, but I cannot get the metal bits out. I have tried fishing it out with a wire to no avail.
Does anyone have any suggestions short of taking the entire pan off then having to replace the seal?
Re: 97 Civic Oil Plug Problem
Use a strong magnetic to bring them up to the hole????? But i guess the question is 1# is your oil pan leaking ??? If so its probably worth taking the pan off and resealing it. If not then try the magnetic trick. Good luck man
If the wings are like a drywall anchor, I might leave them alone if you can't get them out easily.
I don't think they will hurt anything on the bottom of the oil pan. JMO
Xuhme
21
08-07-2023 03:40 PM
LionSpratt
01-29-2017 11:07 PM
mistermenphis22
04-03-2016 08:06 AM
