Honda civic 2000 shaking
Rep Power: 0 Honda civic 2000 shaking
Hello everyone , i have a weird issue with my honda civic 2000 LX , the car is shaking when it idle i mean when its not moving plus some times i hear the ac clutch trying to engage then stop then engage again then stop and so on what i have here kindly help me , i am thinking about the tps sensor i don't know i am just guessing
Best regards
Best regards
Re: Honda civic 2000 shaking
IF the idle RPM is too low it will shake,..and if it runs poorly it can idle too low and shake, (CEL on? Low power?)
the computer will shut off the AC below about 600 RPM then let it kick on when RPM goes above 600. This cycle will repeat endlessly.
If the IAC is stuck or clogged, this happens.
LX....probably stuck.....Tap on the IAC valve and see if rpm comes up to normal?
Clean throttle body, clean IAB screw passage if equipped?
Reset minimum air rate, relearn base idle?
Remove the air filter and you can look into the throttle body.
Remove the air filter lower housing to access the throttle body easier.
Look for item #6 in post #1 here: https://www.civicforums.com/forums/1...e-up-mods.html
More links:
https://mobiloil.com/en/article/car-...cleaning-guide
http://www.popularmechanics.com/cars/how-to/a81/1272341/
http://www.familyhandyman.com/automo...-body/view-all
More links:
jessicakaybby
04-20-2015 12:11 PM
