Possible Major Electrical Issue?
Old 05-31-2015
HiImBrandon's Avatar
HiImBrandon is an unknown quantity at this point
Yesterday, while in Miami after a 4 hour trip from Tampa, my battery light turned on and about 30 minutes later my car shut down. I had to have the car towed and the alternator replaced. That fixed the problem of the car dying and the battery light being on the dash but after I got the car back the wheels became hard to turn as if I no longer had power steering and now nothing on my instrument cluster works. The rpm and speed gauge were acting up when the car started to lose power before it shut down so I figured the alternator being fixed would cure that but evidently not. I also cannot get the car out of park without putting the key in the override slot, popping it in neutral, then starting the car. All of this happened once I got the car back from having the alternator replaced. Any insight is appreciated. I managed to get the car back home to Tampa but I'm afraid it might strand me again due to one of these new issues.
Old 05-31-2015
Super Moderator
Poopies's Avatar
Re: Possible Major Electrical Issue?
Any fuses missing/broken? How does everything look under the hood?
Old 05-31-2015
Guesses:
Power steering belt was left loose?
Alternator bolts were not tightened, possible PCM damage as a result?
Contact the shop that did the repairs and see how they want to handle their problem.
Old 05-31-2015
usajags84's Avatar
usajags84 is an unknown quantity at this point
It sounds like the alternator is loose.As is the power steering check the tension on the belts. But Id wanna call the shop that did the work and see how they want to proceed was it a chain store like a pep boys or firestone?
Old 06-01-2015
mikey1's Avatar
take it back
7thgensurvivor
38
08-29-2015 11:50 AM
Hiryuu
06-06-2015 03:00 PM
WLakers
05-04-2015 06:23 PM
JoeB16
61
10-16-2003 07:58 PM
supercivic01
26
01-26-2002 10:11 AM
Quick Reply: Possible Major Electrical Issue?
